Okay to extend some wires?
Old Nov 30, 2003 | 06:12 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
I was looking at the wiring under my hood today and it all looks pretty good...with the exception of the ignition. I had to "modify" my DuraCrap distributor to work with the GM ignition module and Accel ignition this afternoon. (Locked out mech advance and removed the vac advance canister.) It's strange how much that Ford distributor resembles a GM small-cap distributor with all that stuff removed.
Anyway, back to the original question. I want to elongate some wires and move them to the cab of my Jeep. The question is...how much wire splicing/elongation is too much? Will extending the wires from the wiring harness to the module screw up any resistances or the like? As it looks, I 'll have to elongate them by about 8 feet to get them where I want them and routed through existing firewall holes.
Thanks in advance (no pun intended)
Old Nov 30, 2003 | 06:47 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I don't see any problems.
Old Nov 30, 2003 | 07:12 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
So...strip, solder, shrink wrap, and all should be fine. Cool. Thanks!
Old Dec 1, 2003 | 08:27 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
It should be just fine.
Old Dec 1, 2003 | 09:14 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Thanks guys. I know that this sounds like a typical newbie question, but I had to be sure. I screwed an engine up once by "redoing" a wire that I shouldn't have "redone". It was a resistance-calibrated wire to the ignition in a 1974 Jeep CJ5. The short story is that I rewired it without knowing it had a specific resistance. It ran great for about a month, then it died on the side of a road. I cranked on it a few times, the crankcase filled up with fuel vapors, I cranked on it a little more, and BLAMMO!!! Crankcase explosion...it cost me a new engine (AMC 304) and a lot of cussing.
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Sep 4, 2015 07:57 AM
theshackle
Aug 23, 2015 03:49 PM
Linson
Aug 21, 2015 02:12 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
