intake suggestions
Old Dec 3, 2003 | 12:40 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
intake suggestions
I have a '92 LO3 engine and I just got some pre-87 '416' casting heads. Is there an intake I can use that will make the heads an easy bolt on and allow me to keep the TBI?
Any suggestions.
Old Dec 3, 2003 | 12:41 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
weiand 7525 with a TBI adaptor plate.
Old Dec 3, 2003 | 12:50 PM
azvolfan's Avatar
Thanks Dewey.
Old Dec 3, 2003 | 12:54 PM
azvolfan's Avatar
Just looked that intake up on weiand.com and it says it is not 50 state legal. I need something with egr so I can pass emissions.
Are there any others.
Old Dec 3, 2003 | 12:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you really wanted to (and if you're into performance, you dont) you could keep the stock intake. you just need to elongate and mess with the 4 center bolt holes.
otherwise, pick any carbed intake you want, and run a adapter plate.
Old Dec 3, 2003 | 01:02 PM
Dewey316's Avatar
Car: 1990 Camaro RS
that intake DOES have EGR. just doesn't carry a C.A.R.B. number.
Old Dec 3, 2003 | 01:12 PM
azvolfan's Avatar
Thanks for the info Dewey.
Old Dec 3, 2003 | 06:00 PM
azvolfan's Avatar
So with that TBI adaptor plate the TBI will just bolt right on. No holes to drill or anything like that?
Old Dec 3, 2003 | 07:25 PM
Dewey316's Avatar
Car: 1990 Camaro RS
yes sir.
there will be some minor stuff to take car of. like throttle brackets, where to mount the coil, and fuel lines. nothing big and involved though.
Old Dec 4, 2003 | 12:34 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I just went through the major pain in the *** known as swapping to a carb manifold, I can help ya' when the time comes around!
Old Dec 4, 2003 | 03:57 PM
azvolfan's Avatar
Thanks Tony.
Old Dec 4, 2003 | 04:37 PM
Ronny's Avatar
edelbrock has a nice TB manifold (Performer). 1500 rpms-5500rpms). Designed for car. Probably no EGR. Was not Holley designed for truck?
Old Dec 4, 2003 | 08:07 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Actually you can have my TBI manifold for cheap if you want after I pull that bolt out, that thing was really really easy to install.
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
transamgta87
Sep 1, 2015 07:07 PM
InfinityShade
Aug 22, 2015 08:00 PM
