Need Pics for those with Holley 670 TBI
Old Dec 4, 2003 | 12:15 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
For those individual that have the Holley 670 TBI, could you please post pictures of your set up. (the TBI only) Also maybe post the type of engine and HP. Thanks.
Old Dec 4, 2003 | 09:36 AM
Snowdog 91 Formula's Avatar
TBI pictures
Look up my threads with my username....
I would guess my engine put out about 300 or so HP at the flywheel and about 270 at the wheels....
Not too shabby. My setup is in my sig.
May it rest in peace..... The car was totalled on 12/3/2003
Old Dec 4, 2003 | 06:46 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Re: Need Pics for those with Holley 670 TBI
76 IH scout 345 CI about 200HP but lots of torque!!!!!
Does this count??
Old Dec 4, 2003 | 08:45 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Heres mine. Probably around 250 hp, 350 ft-lbs of torque by my estimates, but the cars so buggy that it never stays running good long enough for me to get to a dyno. Hey, Bill, how high above the tbi does that air box sit?
Old Dec 4, 2003 | 09:48 PM
86z/92rs's Avatar
Thanks for the pictures. Here is my Holley TBI I purchased back in 2001 (yes 2001) from a guy by the name of Bill Bates. Planning to use it for my 92 RS. The question I have is in the picture, I have a TPS sensor on the passenger side and I noticed that other Holley TBI have 2 sensors on the passenger side of the TBI. Mine also came with an adaptor to fit 4bbl intake.
Old Dec 4, 2003 | 11:36 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
You have one of the older TB's that do not have the IAC hole drilled out.
I was given one of those and drilled it out myself and added the IAC. You will also need to switch the TPS from your stock TB onto this one so the IAC will clear.
I've never done it but I have seen the remote IAC's.
Might be another option instead of drilling the TB..
The box is about 5" tall. Lot's of them on EBAY. the filters are junk but it adds a little silk to the old sow!!(bling)
Old Dec 4, 2003 | 11:57 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Youll also want to use your stock tbi pod as the mostly old parts and rust (mopar) injectors that the older holleys came with where junk. Delphi now manufactures that same injector that the older holleys use as an oem replacement but i dont know if theyve improved the design or not
Bill,
Damn, 5 inches... The nut on teh air cleaner would stick out through the top of my hood when i close it. Guess itll have to wait untill i have a fancy aftermarket hood.
Old Dec 6, 2003 | 05:27 PM
lo-n-slo's Avatar
hows the quality of that air intake? Would a K&N filter fit on it? Do you know what size the Tube is?
Old Dec 6, 2003 | 09:52 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I don't have any complaints with the rest of it.
The pipe is 3.5"OD
The filter looks fine and is double wire mesh but after a week of driving it, I could start to see daylight through the filter.
The air box is actually 5.5" tall.
HTH
Old Dec 7, 2003 | 07:52 AM
86z/92rs's Avatar
Bill USN-1, can I use my IAC and TPS from my current TBI and install it into the Holley TBI? Do you remember what size drill bit you use to drill the hole to make provision for the IAC?
Dimented24x7 and Bill USN-1 , Thanks for the advice.
Old Dec 7, 2003 | 10:28 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
To be honest I don't remember the drill size.
You will have to drill the outer large hole then find a tap for the thread pitch on the IAC.
Once the outside is drilled then you have to drill the inner port.
I used a small center hole and used a larger bit to make the taper for the seat of the IAC.
If you don't have the resources, I'm sure a simple machine shop would do it for next to nothing.
I used the TPS from my GM TB. IIRC the original are not adjustable, But most of the replacements are.
Old Dec 7, 2003 | 08:14 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
no pics but check out the sign
Old Dec 7, 2003 | 09:40 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
"SMIB"
or
"SQUID"
Old Dec 8, 2003 | 09:13 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
lol
MustangBeater20
Oct 29, 2022 09:20 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
InfinityShade
Aug 22, 2015 08:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
355tpipickup
Aug 19, 2015 10:02 PM
