Need quick help before I put my 670 on today
Old Dec 9, 2003 | 05:02 PM
K5er4Life's Avatar
Car: 87 Blazer
Engine: 383 stroker
How do I adjust the fuel pressure on the holley 670? I have a good idea of where the regulator is but I want to make sure I got the right pressure. thanks
Old Dec 12, 2003 | 04:50 AM
chevy8ford's Avatar
Car: 88 Firebird
I'm not sure, but i think you have to remove the injector tree to do it. I know that in the past people have drilled a hole underneath which gets around this i think, but i'm not sure.
Old Dec 12, 2003 | 08:55 PM
K5er4Life's Avatar
Car: 87 Blazer
Engine: 383 stroker
Yeah I have heard that there is a screw that is behind the injectors but I dont know which one it is.
Old Dec 13, 2003 | 10:42 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: Need quick help before I put my 670 on today
pop off the brass cap on the very top of the regulator. I had to drill it out because it wasn't budging... but you might have better luck. I think it uses a 1/4" allen wrench to turn.
Old Dec 14, 2003 | 12:29 AM
K5er4Life's Avatar
Car: 87 Blazer
Engine: 383 stroker
Thanx Ill give it a try.
Infested
May 22, 2018 11:56 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
crazynights
Aug 21, 2015 06:53 AM
