Crazy Crazy Tach...
Old Dec 14, 2003 | 01:27 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Crazy Crazy Tach...
A couple of months back my tach started reading approx. 2000-3000 rpm's above what it's actually running at, actually may be more. When I run WinALDL it reads the actual RPM's just fine. The tach doesn't bounce around or anything, just steadly reads WAY over the actual RPM's.
Anyone know what causes this to happen?
Thanks in advance!
-Josh :lala:
Old Dec 14, 2003 | 10:30 AM
Car: 1991 Camaro RS
Awww, come on. Someone must have had this problem before, at atleast knows whats going on!
Old Dec 14, 2003 | 04:26 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Mine too!
My tach is doing that too and as of yet, no one on this board has given me any useful information. I replaced the coil, cap & rotor with MSD components, but it still does it. Hopefully I can get it fixed soon.
Old Dec 14, 2003 | 06:47 PM
Car: 1991 Camaro RS
The only thing I can come up with is the actual tach on the dash (the electrical unit) is bad....maybe a new instrument cluster will fix it.
Old Dec 14, 2003 | 10:06 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
Mine was doing the same thing, now its maxed out all the time. I don't know what causes it. I'm going to try a new cluster. I'd like the 145mph speedo anyway!
Old Dec 15, 2003 | 06:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it is the guage.
it is VERY common. a new tach SHOULD fix it, but when buying a used one, it may have the same problem, don't be suprised if it does.
Old Dec 15, 2003 | 09:41 PM
Car: 1991 Camaro RS
Stupid stock tach's! That thing had me worried for the longest...till I hooked my cable to it and ran WinALDL. Then I know the ECM was fine
Old Dec 16, 2003 | 08:08 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
obviously the ECM knows the engine speed, otherwise it couldnt run...
the problem isnt on the motor or ECM part... the problem is that the stock tachs wear out and break.
you can either send yours to be fixed ($$$) or replace it.
if i knew or could find how to fix it to be accurate again, i would tell ya... so far the only "tach hacking" was what someone posted about making a V6 tach work on a V8...
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
