Bone Stock TBI Running Rich
Old Dec 15, 2003 | 06:59 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I have a 93 v6 Pickup that is running rich at idle. It set a code 45 yesterday for the first time. Today, it seems to be down on power getting on the interstate.
I checked it out on my scantool and the block learns are pretty steady in the 103-104 range. Integrator is at 122.
The TPS and coolant temp sensors looked to be reading OK. The 02 sensor was replaced last winter and seems to be functioning as it's supposed to.(fluxing rich/lean regularly).
Fuel pump has been replaced in the last 3 years and so has the filter(albeit it could used replaced again)...
Truck has 117k miles on it and is a daily driver.
Any ideas?
Thanks,
Old Dec 15, 2003 | 07:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i would suggest looking at spark. plugs/wires/cap/rotor
also pull the plugs and verify you are really running rich.
BTW, what exactly is code 45 in your application (too lazy to see what computer ect, you rig uses.) finding what that code is would be a great help.
Old Dec 15, 2003 | 09:46 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I pulled code 45 from here...I got the code, but with the way my scantool spits out info, I just read '02 sensor rich' on the screen.
Truck runs fine other than lack of power. Doesn't seem to miss or anything.
Thanks for the suggestions...
Old Dec 15, 2003 | 10:05 AM
Dewey316's Avatar
Car: 1990 Camaro RS
also, o2's can go bad quickly , you might try a new o2. like i said, i would pull a plug, and make sure you are actualy running rich.
Old Dec 18, 2003 | 10:54 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Thanks for the help...I haven't gotten back to it as it has been really cold and I bruised my ribs up bad in a fall.
Luckily I haven't had a 'low power' issue since Monday morning..
jaridjohn
Jul 8, 2024 03:49 PM
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
squiggy2
Aug 9, 2015 09:30 PM
