View Poll Results: Did you dremel the dowel pin on your LT1 Cam?
Yes, I did, I don't see how you couldn't?
81.82%
No, crap no, what the crap are you talking about
18.18%
Voters: 11. You may not vote on this poll
LT1 Cam: Did you have to dremel down the dowel pin
Old Jan 9, 2004 | 07:40 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Hey guys, I didn't do it because I wasn't aware that you had to, I'm wondering who did and who didn't. Mods: I just thought that this would over take the sticky one at the top, so I just thought we could link to this.
Tony
Old Jan 9, 2004 | 09:45 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
Tony have ya started the engine up yet? if ya have and you dont have a hole rubbed in the timing cover i wouldnt worry about it, on the other hand when i did my install i just put it on the bench grinder till it looked like the peanut cam with sprocket. i measured the pin on the cam i got i had about 3/8 of it sticking out of the face of the sprocket so it had to come off.
Old Jan 10, 2004 | 12:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I cut mine down. Took about a whoppin 2 seconds to do. You really need to. i do not think there is enough clearance between the pin and your timing chain cover. Just cut it off to match the pin on the stock cam. It takes just seconds.
Old Jan 10, 2004 | 11:33 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I just tapped mine with the hammer and pushed it in a little farther - no problems and easier than cutting.
Old Jan 10, 2004 | 12:12 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i did my first hott cam install this way but its too messy for the camshaft so now its easier to tap it down with a center punch,hammer and old timing gear...
Old Jan 10, 2004 | 12:24 PM
Z28GEN3's Avatar
Engine: 305TBI
tapping it down is okay but when it bottoms out like the one in my cam you have no choice.
Old Jan 10, 2004 | 09:04 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I tried tapping mine down but it wouldn't move and I was afraid of mushrooming it to the point of not fitting the hole in the timing gear. I wrapped the cam with plastic wrap to keep grinding dust off, then ground the pin off.
Old Jan 11, 2004 | 07:21 AM
vwdave's Avatar
Removed, cut with hacksaw, cleaned up with bench grinder, reinstalled, finished.
Old Jan 12, 2004 | 11:01 AM
deadtrend1's Avatar
Cut down, installed .. four months later a hole formed in my timing cover, took it apart, hammered it back in, replaced cover, sold car.
Old Jan 12, 2004 | 11:47 AM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
sold the car... lmao
Anyone have pics.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
