is this a good TBI swap
Old Feb 19, 2004 | 04:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my friend owns a 89 GMC truck which he bought and installed a nice 670cfi TBI on. well, he is selling the truck soon and we agreed if i could swap my stock 300 with his 670, we would do it before he sells it. so my question is.. first, will this 670 bolt right on my car, and will their be any complications? minor or major, cuz keep in mind, this is a FREE 670 and its about a year old.
Old Feb 19, 2004 | 04:40 PM
Ronny's Avatar
what is advantage to using the 454 tb on a stock application?
Old Feb 19, 2004 | 05:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
none now i know, but it is FREE. if it isnt gonna do anything wrong to my engine, then why the hell not?
btw, he has it on a V6
Old Feb 19, 2004 | 06:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You cannot just use it. There are a few things to consider. Would you be running it with your stock injectors or the ones that came with it. If you use the ones that came with it you will have to burn a new prom so that they work at the right psi. Also that unit has 2" bores and your stock intake only has 1 11/16". Meaning that there will be a lip in the way of the im comming air and cause turbulence. The stcok intake is more than capable of supporting the power levels of stock and mildy modded LO3's. You only need that TBI unit when you have heads and cam combos that max out tghe stocker. If I were you I would keep it for futur mods. It will do nothing for you right now but cause headaches. Read the "all go here" posts at the top of the page for more info.
Old Feb 19, 2004 | 11:43 PM
steve8586iroc's Avatar
I would go to a salvage yard and pick up a tbi off a Camaro or Caprice, then swap that one on his truck and save the 670 for later on when you decide to do more extensive mods to your car.
Steve
Old Feb 19, 2004 | 11:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i dont have the money to buy one from a junk yard and the junkyards around here have been stripped of everything anyways
Old Feb 20, 2004 | 12:01 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You can get a stock one on ebay for as low as 20 bucks.
Old Feb 20, 2004 | 11:40 AM
Ronny's Avatar
not all 454 TB's are the same. injector size and fuel pressure varies per application on original donor car.
Old Feb 20, 2004 | 01:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
my friend says he ordered his off jegs if that makes a difference?
Old Feb 20, 2004 | 01:33 PM
Ronny's Avatar
you need to know the injector size. they vary. mine was had ebay. an incomplete list is somewhre on this forum and crossfire forum. i believe at least 3 diff injector sizes.
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
justin57
Aug 20, 2015 07:05 PM
