need to know what cam?
Car: 89 Camaro RS
Engine: 305 TBI LT-1 Cam/TBI Chip
Transmission: Automatic
I cant seem to find out anything about the cam in a 305 TBI 89 RS
Any help will be great!. I know I have rollers thats about as far as I have gotten.
Car: 89 Camaro RS
Thanx, Now will anyone recommend a cam for stock heads and ehxaust manifold. I just want some temporary boost in power.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
crock
I have a 89 rs it has a 90 vette 350 using stock 89 rs heads, intake, exhaust manifold, but has the l-98 cam, it runs pretty strong and seems to work good with the ecm
Car: 89 Camaro RS
So would it be more cost effective to swap to an L-98 or LT-1 cam as opposed to buying a performance cam from a manf. Like comp cams and what not. Was looking at some of CompCams High Energy and Dual Energy Cams. If anyone has had experience with these cams speak up. Any help would be great.
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
the only combo I have been able to come up with is the edelbrock 3702 cam and 3704 intake. 125.00 for the cam and 219 for intake, Jegs
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i'm running and UltraDyne 272/282HR-12
it is 206/216 .447 .447 112
with the stock heads and intake it is actualy doing pretty good, it def. requires alot of tuning to get it right. with everything else stock, and that cam, with headers and catback, the tazzo is telling me 14.7 or so in the 1/4. i'm going to hit the track as soon as it opens and see what it runs.
UD is not in buisness anymore, but the cam designer works for Lunati now, you could probably call lunati and get this grind through them.
Car: 89 Camaro RS
Purchasing an LT-1 cam 3-2-04. I will let you know how the swap goes. It will be my first swap of any kind so I hope it goes well.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 1991 camaro RS
Engine: 305 Carb
Dewey316 i'm running and UltraDyne 272/282HR-12
Car: 89 Camaro RS
I have sent my STAGE 1 TBI chip back to TBI CHips. Brian said he would give me a deal. All I did was ship it to him and he is flashing it for the LT-1 cam specs for free. Saved me alot of money. I get the LT-1 cam, from a 95 z28, this tuesday. Hopefully will have the cam and new chip in by the end of this week or early next week.
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
Originally posted by del91_305
Dewey316, i am also getting ready to do a cam swap. My engine is all stock right now, and im also going to swap the intake. Are you pretty satisfied with that cam? And also where did you get it? thanks.
but the cam makes great power.
UltraDyne is out of buisness, the cam designer now works for lunati, his name is Harold Brookshire, give lunati a call, and ask for him, tell him you are interested in his 272/282HR-12 UltraDyne Cam, he will hook you up.
Car: 89 Camaro RS
Originally posted by ShiftyCapone
I would still learn to burn your own chips. His chip will only get the car close and will not maximise your new cam.
Car: '90 RS
Engine: 377 LSX
Definitely but budget wont allow it.
Car: 89 Camaro RS
That makes sense. At least you are aware of it. You car will still be very drivable with an off the shelf one. Plus I think you can send them back to him if it is bunk or really far off. I would try to at least datalong (free software) and send him that. That should help him get it even closer.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Car: 89 Camaro RS
Does anyone sell. Premade Cables to hook up. So I can do some Data logging im not really. Technically inclined with a solder gun or knowing about resistors and what not.
Car: 89 Camaro RS
Sounds like you are on your way to a better chip.
Car: '90 RS
Engine: 377 LSX
Hope So. I have to save up for a premade cable. Good thing my mom is buying a new laptop so I can have her old one for Data logging.
Car: 89 Camaro RS
Last Reply to this topic. I am keeping full documentary of my cam swap and the ultimate TBI mods at my website crokiller.com I will try to keep it up to date. Before I start would it be a good idea to replace the gasket between the TBI unit and the intake.
Car: '90 RS
Engine: 377 LSX
Car: 89 Camaro RS
Well maybe not the last.
Here is a pic of my LT-1 cam.
Also here is a direct link to my website where I am documenting this. http://www.crokiller.com/homepage.phtml
