High mileage TBI's post up
Old Jan 7, 2008 | 01:01 AM
  #201
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Re: High mileage TBI's post up
My goal for my 90 camaro was 300k. I made it to 303,000. Took the engine and trans out cause I was bored with it. Still ran hard the last day, didn't smoke too bad either.
Old Jan 7, 2008 | 02:25 AM
  #202
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
135,000 on rebuilt engine, trans is still the original, hasnt been rebuilt.
Old May 13, 2013 | 09:19 PM
  #203
ch8ind's Avatar
Car: 92 camaro
Engine: 305 TBI
Transmission: 700 R4
Axle/Gears: 2.73 open
got my l03 with 102,000 on it. few months later i got into 106,000. its my daily driver so a few more years she will be up there. poor maro. my dads poor lg4 took around 100,000 just from me with one oil change. that thing has 180,000 now with the tranny finally done. still solid
Old May 15, 2013 | 03:01 PM
  #204
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Originally Posted by kevm14
Old thread. Here I am a year and a half later. Still have 45-53psi cold start and 15psi hot idle. Oil pressure drops during full throttle acceleration, but not during a brake stand, not when the oil is still cold, and not when I drain a quart from the crank case. Still makes noise for the first few minutes after a cold start (light load). About 4000 miles to a quart of oil. Still haven't seen a single whisp of oil out the exhaust. And I keep driving and beating on it. I'll check back in another year and a half.
280k...still doesn't smoke on startup, even after sitting, nor does it smoke any other time. Leaks all kinds of oil though...
Old May 16, 2013 | 12:58 AM
  #205
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Had an 87 G20 Cargo van yrs ago over 230k on it never smoked pass smog well.
Smoothest idling most reliable vehicle Ive ever owned.
It was loose as a goose but never let me down.
Old Jun 11, 2013 | 12:17 PM
  #206
Dougie91's Avatar
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
Around 290,000 on original engine. Looks like it has 200,000 less though lol
Old Jul 7, 2013 | 09:02 PM
  #207
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
91 camaros RS, lo3 305 tbi 5 speed, 188k and counting, All Stock except clutch.
Old Jul 14, 2013 | 04:34 PM
  #208
DesertRS's Avatar
Just turned 500,00 miles on my '89 Camaro RS (TBI 305). The best part is it has the original engine that's never been rebuilt. No smoke at all and passes California smog every time. This car is still my daily driver to and from work (a 120-mile round trip). If you take care of them, half a million miles is no problem.
Old Aug 6, 2013 | 10:46 PM
  #209
92Roadie's Avatar
Car: 92 Roadmaster
Engine: l05 350
Transmission: 4l60
Axle/Gears: 2.56 non-posi
1992 Roadmaster with an l05, 274,000 original miles!
Old Aug 7, 2013 | 05:35 PM
  #210
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I read this post somewhere an has to take a pic of it cause it related to me extremely well ... I've had the car for 6 years and I had 180k when I bought it (one owner (60yr old lady )all original ) ...I started modding immediately headers, exhaust , ignition, 1.6rr, etc. then finally 4.10's suspension etc. and about 2.5-3 yrs ago I said when I blow it up ill rebuild it better or swap in a 327.... Meanwhile after beating the ever lovin **** out of it and revving past redline several times ... It never blew up ! And I got tired of waiting so I yanked the damn thing out .. And now I'm rebuilding it
Old Aug 7, 2013 | 07:35 PM
  #211
92Roadie's Avatar
Car: 92 Roadmaster
Engine: l05 350
Transmission: 4l60
What are your plans/goals for your buildup? Before I can do the engine mods I want, there is a few more things to square away. But,eventually there'll be a comp cam, holley tbi, and hedman shorties under the hood!
Old Aug 7, 2013 | 09:09 PM
  #212
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
152K on the 89 LO3. Original miles. Smokes pretty bad after a restart. Eats oil fairly quick. Develops piston slap when warm. However she still fires up and pulls me around on my off days. Beat it up a lot when my dad passed it down in HS. Ran ARCO 87 all the time. Terrible choice. Now I just baby it and stays mostly garaged
Old Aug 7, 2013 | 09:20 PM
  #213
Car: 1991 firebird
Axle/Gears: 4.10
Check my thread in TBI section ..." LO3 rebuild ( HP estimates ) "
Old Apr 21, 2014 | 01:17 PM
  #214
Bulslayer85's Avatar
Car: 89 Camaro RS
Engine: 305 v8
Transmission: Automatic(modified)
Mines a 89 RS with the 305 tbi, 318k miles and even with the few problems i,ve had with it the engine still starts up and runs good, kinda wondering if this is one of those "hard to kill" engines, i was getting worried about doing a rebuild soon but i see a lot of you posted that your engines are still original non rebuilt.
Old Apr 21, 2014 | 01:31 PM
  #215
Dragonfromtiger's Avatar
Car: 91 Camaro RS
Engine: 5.0
Axle/Gears: stock
I've only owned my 91 t-top 305 for a few months. It had 183K on the clock when I bought it, well over 184k now. Runs strong, everything works, even a/c except 3rd brake light. Has some issues but trying to sort them out one at a time.
Old Apr 21, 2014 | 11:08 PM
  #216
bluedart's Avatar
Car: 91 Caprice Wagon
Engine: 350 L31-R
My 91 Caprice has made it 339,300 miles on an original L03 305 engine, never been unbuttoned. Second transmission, replaced at 140k and a soft overhaul at 260k. Timing chain on the engine just skipped a tooth recently though, so I cannot time it and it's looking like a good opportunity to do a crate 350.
Old Feb 23, 2015 | 06:29 PM
  #217
Firebird1012's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 305 v8 5.0L Lb9
210k on my 91 firebird body and motor. Engine has never been taken apart (to my knowledge) all original paint no rust.
Old May 24, 2015 | 11:21 PM
  #218
ledman66's Avatar
Car: '85 Trans Am
Engine: 305 LG4 4BBL
88 IROC-Z 305 TBI with 215,298 miles, never rebuilt all stock. I do get a stall now and then after its warmed up, and I go to shift to drive or revers, but then I I start it again and it's fine.
Old May 28, 2015 | 06:20 AM
  #219
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
My 89 TA only has 82 k on it. BUT my 91 k1500 5.7 tbi just turned 330k and still runs strong and uses no oil.
Old May 30, 2015 | 06:59 PM
  #220
ledman66's Avatar
Car: '85 Trans Am
I wish I could say the same thing. I get some blue smoke on start up, probably valve seals I am told is really common, and I use about a half a quart every 1500 miles...BUT my valve cover gaskets are leaking too, so that does not help
Azrael91966669
25
Jun 20, 2017 04:04 AM
dutch930
Sep 11, 2015 06:58 AM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
