need pictures of engine without air cleaner on
Old Feb 28, 2004 | 12:02 PM
RedRS90's Avatar
Hey guys i need some pictures of your engines with your air cleaner assembly off....basically pictures of your coils and distributors.....I put a 350 in my car and I'm having trouble hooking everything back up....kind of a pain in the A$$
Old Feb 28, 2004 | 01:36 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Attached Thumbnails need pictures of engine without air cleaner on-asfhdhb2.jpg
Old Feb 28, 2004 | 05:53 PM
RedRS90's Avatar
maybe you can just answer me this..... the coil....it has one side that is kind of like a hook so you can slide it....does that part go on the side where the bracket mounts for the throttle cable and also does it really matter which way the distributor is turned....b/c I'm having trouble plugging all of the wires into everything
Old Feb 28, 2004 | 05:56 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yes, the hook side of the coil goes on top of the throttle cable bracket bolt or stud. I am not sure about turning the distributor, though.
Old Feb 28, 2004 | 07:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It won't matter how you have your coil posistioned. It is just easier to put it back in the stock spot that has the two connectors facing the firewall. What else are you having trboule hookig up? There is two wires that go onto the dist and two on the coil. You can't mix and math them either and they only go in one spot.
Old Feb 29, 2004 | 05:10 PM
RedRS90's Avatar
i'm just having trouble with the wires reaching that module at the bottom of the distributor, why does swapping an engine have to be such a pain lol, I'm so close yet so far away b/c of all this little crap that turns into a problem.
Old Feb 29, 2004 | 05:47 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well its all part of the fun. You may have your wireing harness caught up on something. You should have plenty of room to reach the back of the dist.
Old Feb 29, 2004 | 06:02 PM
RedRS90's Avatar
yeah I'm workin on it, everything is connected for the wiring harness besides that...and the 3 sensors on the drivers side of the engine block, I havent connected those yet. after that I just have to prime the engine and start her up, I'm excited for this to be done with. I've been without my camaro since the end of september....its been a real slow process...me not having all that much money and all
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
