how to remove injectors?
Old Mar 7, 2004 | 03:05 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
is thier a special trick to removing my injectors from the pods on my TBI? i want to know before i try to just yank them out
Old Mar 7, 2004 | 03:59 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
torx bits...
Old Mar 7, 2004 | 04:14 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You have to use a fulcrum (it's recommended by the manufacturer). What i did was get two screwdrivers, put one of them long ways next to the injector and then get your other screwdriver (should be a flathead), lay it on top of the screwdriver, and pry up on the injector (actually the part in the center that sticks out). Sorry, I'm not good at explaining things. Hope this helps, though!
Old Mar 7, 2004 | 04:15 PM
vjo90RS8's Avatar
Car: 2002 Z28
use 2 screwdrivers, one on the injector pod as a pivot and the other to pry it up. Thats how Haynes recommends to do it.
Old Mar 7, 2004 | 04:29 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks, i figured they just pushed straight up and out.. thats all i really wanted to know, got them out no prob, but i have a prob when i put them back in
https://www.thirdgen.org/techbb2/sho...54#post1722854
Old Mar 7, 2004 | 06:54 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The roll-pin is on the base of the injector. Turn it upside down and itll be poking out the bottom. There is a notch in the injector pod that it keys into. Also make sure to lube the o-rings with clean motor oil or youll be pulling them back out again after the rings tear. Ill post a pic in a second.
Old Mar 7, 2004 | 07:03 PM
Car: 88 Camaro SC
Engine: SFI'd 350
the circle markes where the roll pin goes in the pod
Old Mar 7, 2004 | 07:04 PM
Car: 88 Camaro SC
Engine: SFI'd 350
and here is the roll pin vader talked about. Line them up and push teh injector in
Old Mar 7, 2004 | 10:50 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok i have them lined up both correctly, i noticed the notch for each injector is on opposite sides, so both times i had only one injcetor in the correct way. now they r in the correct way on both sides, but im gonna wait till tomorrow to get my gasket and install the fresh gaket before i attempt to tighten it all down again and start it.
Old Mar 8, 2004 | 03:40 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
LOL, I'd have secound thoughts about doing it if a Haynes manual said to do it. If it isn't obvious I have some beef with them...
Bruce (90RS305)
Old Mar 8, 2004 | 11:33 AM
Ronny's Avatar
engine oil will work as will trans fluid to reinstall. i used a silicone faucet grease.
Old Mar 8, 2004 | 11:34 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yes i got the injectors in, wont know if it works till i get the new gasket though.
Old Mar 8, 2004 | 09:50 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I tried taking off mine and broke the little plastic pieces that hold them down, so now they are both just kinda... sitting... in there. The previous owner dangerously overheated the car MANY times so every little plastic piece under the whole hood just brake off, owell.
Old Mar 8, 2004 | 09:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well i got the gaskets in and the injectors in the right way, and it works fine again w00t.
one guestion though, would rmoving the filters on the inejectors themself increase flow?
Old Mar 8, 2004 | 10:04 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Not really, but itll alow any garbage floating around in the fuel system to possibly lodge itself in the injector and foul it up.
Old Mar 9, 2004 | 04:08 AM
90RS305's Avatar
That can't be good
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
Thornburg
Aug 27, 2015 08:33 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
