I have a plan
Old Mar 10, 2004 | 06:05 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
I have a plan
I have my car torn down to have the valves done I what to chang the cam but I have a 327 siting haer it look like i could put it in. If I put the stock heads on with my holley intake stock tb will in run like a 305 or will it have more power? The 327 has a cam in it not shur what but the rest of it is stock 69 chevy is this a good plan or run the hell out of the 305 and do something eith the new heads
Old Mar 10, 2004 | 06:17 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: I have a plan
That is a non roller motor with a cam that is most likely not FI friendly. You need a cam with 112 LSA or higher and you have to be able to burn your own chips. The stcok heads will not worj either because of the valve train differences. Whether or not it has more power depends on whats in it. You cannot geuss just based on displacement alone.
Old Mar 10, 2004 | 09:20 PM
Engine: 5.8
what is different about the valvetrain?
Old Mar 10, 2004 | 09:24 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Self allinging vs non self allinging.
Old Mar 10, 2004 | 09:33 PM
Engine: 5.8
so i use my stock rockers
Old Mar 10, 2004 | 09:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is not that easy. You need to use a roller cam and that block would need to be machined to accept a roller cam. Also, using a roller cam would require you to use a complete roller valvetrain. You could bolt on a set of modern heads after the block is machined and re-use your old stuff but moet likely you would need different length pushrods.
Old Mar 10, 2004 | 09:50 PM
Engine: 5.8
if you can use a set of l98 on a older motor with on mods to it then I think you could use a set of lo3 heads.
Old Mar 10, 2004 | 10:20 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am having trouble understanding this statement but I think you are saying if you can use L98 heads than you can use LO3 heads. You are correct but the same conversion applies to both. You may want to do a bit more research on the 327 motor and what it takes to use a non roller motor with TBI.
Old Mar 10, 2004 | 10:39 PM
steve8586iroc's Avatar
Shifty I think your overcomplicating the roller block head swap issue. All he needs to do is use his stock rockers with standard flat tappet pushrods or use guide plates and standard flat tappet pushrods and rockers.
2KAB, do you still have the heads for the 327 or is it a short block only? If you have a complete longblock just use it with a good intake and if your unsure of the cam you could swap it out for one you know will be easier to tune a chip for. JMO.
Steve
Old Mar 10, 2004 | 10:44 PM
Engine: 5.8
Ok when you use a set of 87 and newer heads you need a set of Self allinging rockers not a rollor cam you can use a hydraulic cam setup it is not the cam that requires the Self allinging rockers it is the head.
Old Mar 10, 2004 | 10:50 PM
Engine: 5.8
yes it is a longblock but the heads have no accesory holes.
Old Mar 10, 2004 | 10:54 PM
You also need new longer pushrods for a non roller cam (or flat tappet cam) engine. Why do you want to use 305tbi heads on a 327? If thats all you have i say go for it. the 327 is a much better starting point than the 305 and has better rpm capabilities. With a mild cam it should be a strong running combo, just don't forget your compression is going to be higher but not so bad that it should give you any real problems. You may need to run premo all the time though.
Seve
Old Mar 10, 2004 | 10:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Correct. You can use a flat tappet or just hydraulic cam in a roller block with roller lifters and stock valvetrain. Your 327 is not a roller block though. Also, it is very hard to find a flat tappet cam that has the necessary specs that TBI tunability require.
Old Mar 10, 2004 | 11:01 PM
Engine: 5.8
I just had a valve job dun and it costed $200 so I would like to get a little life out of them?
Old Mar 10, 2004 | 11:06 PM
Shifty you may want to reread your last post. Do not use roller lifters on a flat tappet cam. Your last statment is a little confusing too. Most stock FT cams or even mild cams are very close to the stock tbi cam. Any cam that will make good vacuum at idle sould be easy to tune for tbi or ant other efi system for that matter. I have both an 85 and an 86 IROC the have ft cams and the specs on the 85 are the same as the 87 350tpi and the specs on the 86 are almost identical to the 305tbi cam. A ft cam shouldn't be a problem to find a good one to work in his combo.
Steve
Old Mar 10, 2004 | 11:07 PM
Engine: 5.8
is this an ok cam duration at .05 216/228 lift .454/.480
Old Mar 10, 2004 | 11:11 PM
Should be ok with a good amout of chip tuning. Thats pretty close to the lt4 hot cam. Whats the LSA on the cam?
Steve
Old Mar 10, 2004 | 11:15 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Steve
You are absolutely correct. I meant to say that you can use a flat tappet cam with the right lifters in a roller block. I just did a little shopping and you can find a few mild tappet cams that would be tunable with TBI. You may have a little lope with the narrow LSA's but that is okay as long as you can tolerate it. Thanks for keeping me on my toes.
Old Mar 10, 2004 | 11:17 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
That amount of lift is right at the max of stock heads. You can get away with it if you have the right springs and do all of the necessary clearnace checking but it will be close. I would shoot for a cam with no more than .460" lift if you are using stock heads.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Zell1luk
Sep 29, 2015 10:36 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
