All with headers come in.....
I want to know who has egr problems after a header install. I put this in the tbi forum because this is a tbi egr specific question. I know out cars have an agr valve effected by backpressure, so I would assume headers play a big role in it's operation.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes EGR does work with the proper back pressure but there should be enough manifold vacuum to keep it functioning properly. I think people run into problems with larger primary sizes. When they get to big the exhaust pressure needed is not there and the EGR and get goofy. Any set of 1 1/2" or 1 5/8" primaries should result in normal EGR function. Are you having problems with yours?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you run a large (for a 305) cam, a free flowing intake, and have a large throttlebody, it MIGHT play with it.
but at that point, you wouldnt have much vac for your accessories either.
Car: '90 RS
Engine: 377 LSX
Originally posted by Ronny
disable egr in eprom and run without egr ?
redformula88
Oct 14, 2015 06:08 PM
