What grade gas are you using?
I'm running a base L03 and I'm wondering what grade gas everyone's running to get good mileage. Is the higher octane realy worth the extra cash? Once i get through with my mods I'll be using the 93 octane but for now is the 87 good enough? I've been using either 89 or 91, i can't remember recently. What is everyone else using?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
general rule, is to run the lowest octane you can, without pinging.
stock i ran 87, modded, i have 1 chip for 87 which i usualy run, i also have a chip with more base timing, that i use with 92 octane.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
When I was stock I could run 87 without knock. After I bumped the base timing up a bit and modded the car I had to run 92. If you are bone stock with the factory base setting of timing, you can run 87 without any problems.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i run 87.
its a L03. even if you modded the crud out of the motor, its still a street driven 305. i run 87, and i intend to keep running 87, and if they made a cheaper gas that it would run on, id use that.
you do NOT make any more power with higher octane gas, and the l03 is NOT a performance motor that needs higher octane. all you are doing is wasting money.
now if you advance the timing tables from stock, you may need higher octane gas...... but its not a worthwild trade in my opinion since the car will still be a slow dog.... only now its a slow dog that cost twenty cents more per gallon.
Car: 91 Camaro Vert
Originally posted by Farfire70
I've heard that the high octane will help to clean up the engine, true?
FALSE. False. false.
the exact same detergents that are in the highgrade at the pump are in the lowgrade. that wasnt always true, but it is today.
And what abotu additive such as the STP stuff that you're supposed to use every tank?
the "boosters" dont do crud. they may raise it from 87 to 87.3 (a whole 3 POINTS) but you dont need the octane, and they're ineffective anyway. you would have to be RIGHT on the bleeding edge for them to work.
as far as the cleaners.... they're pointless. gas sold at the pump already has detergents, and what are you trying to keep clean anyway? gas is a solovent. unless you let it evaporate and turn to varnish, its fine... the pump is submerged in it. the lines arnt ever going to be restricted for as long as the car is driven, and the injectors cannot be properly cleaned on the car anyway. so after a few hund thousand miles, get your injectors cleaned(properly, off the car), and you're set for thousands more...
Car: 89 RS
Engine: 305 TBI
i run 87 in my 89 TBI.
full exhaust, headers back open element.
of course my ecm is giving me code 43(esc). but it is my inderstanding that is because of the headers.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I like to run the increased timing too.
EVERY 305 I've owned which would be 3 all from thirdgen maros, HATED 87 octane. Stock settings Pinged and Dieseled really bad.
They didn't like cheap arco gas either. And yes I had them all cleaned of carbon too.
I run Union 76 92 oct in the car, 89 oct in the s10, and 87 oct in my 2.8 jimmy.
Car: 91 Camaro Vert
Originally posted by Annihilator
87 is all you need for a nearly stock LO3. Unless of course pinging is an issue.
and if pinging is a issue on your nearly stock L03, then somthing is wrong with it.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i usually run 93 and have run some parial tanks of 100 but the chip i have the timing curve isnt stock..
i noticed alot better throttle respnse with 100 actually but at 3.10 a gallon i cant afford to run that all of the time.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
87 Octane and it'll never get any higher. I just wish I could get my friend with a stock L03 to understand the simple facts of octane. Oh well, its his money.
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Damn..you mean that poster at Sunco stating "94 Octane, time for a spring cleaning" is false advertising...man what a waste. 87 octane from here on in it is.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If it burns, Ill buy a tankfull of it. With only 14 in the city, ~18-20 on the highway, I cant be too picky.
Car: 88 Camaro SC
Engine: SFI'd 350
I agree with not needing high octane for these cars. The only car I had that got high octane was a late model EX accord. Thing would have audable ping on tip in and under very high load with regular.
You guys say that with your 87 octane you don't knock.
Is this just audible knock you aren't hearing... or have you got out a scan tool and looked to see if you are really not getting any KNOCK via the knock sensor.
If you have a knock sensor, you should never have audbile knock.
I thought he knock sensor was designed to catch engine knock prior to it occuring and then lower the timing...or something on those terms.
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
it catches it when it senses it, then it retards the crap out of your timeing.
mr dude:
"so after a few hund thousand miles, get your injectors cleaned(properly, off the car), and you're set for thousands more..."
how do you go about doing this?
-chuck
mr dude:
-chuck
Car: 88 Camaro SC
Engine: SFI'd 350
Basically, the knock retard works like this... The knock module, which is that black thing behind the relays, listens for a peticular waveform from the knock sensor. Once it sees that, it sends out a pulse to the ecm. The ecm takes these pulses and adds them up. Then, the pulses are multiplied by an attack rate to get degrees of retard and they are added into the overall knock retard, which is something up to around 15 degrees or so, accumulated while knock has been present. All of this is then subtracted out from the spark advance. After it stops knocking, the accumulated retard is then decayed out to zero. That, I think, takes around 3 seconds on a stock ecm. One thing about the ks is that it hears detonation before it becomes severe enough to be heard, which is one of the reasons you usually cant hear knock. With a stock exaust on the car (so its quiet) and the windows down I could catch it, but its real faint and hard to hear.
My point was, is that you people say you don't knock, which you should never HEAR knock with a knock sensor, but you may be *knocking* so that the sensor pulls out timing. Depending on the amount of knock and the rate at which it occurs, is the basis for how much timing is pulled. Which is why sometimes you can't tell you are knocking because it doesn't pull ALOT of timing out, but easily enough to cost a half a second at the track without you even knowing it.
Car: '90 RS
Engine: 377 LSX
Originally posted by Twilightoptics
WTF are you talking about? The knock sensor is on the bottom of the block in a coolant passage on the passenger side of the engine block.
Car: 88 Camaro SC
Engine: SFI'd 350
The module is there because the ecm doesnt have the hardware onboard to analyze the signal from the knock sensor. It acts as a go-between so it can look for the waveform of detonation specific to the engine and send a signal to the ecm that it can use, which is a pulse.
Car: 88 Camaro SC
Engine: SFI'd 350
-chuck
-chuck
Car: '90 RS
Engine: 377 LSX
Car: 91 Red Sled
I run 87 when it gets really expensive (now) and just keep a light foot. I've found 87 to work best with my setup believe it or not. I've run 87 and 94 at the track, both with the same results, go figure.
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
If it helps I run 89 on my LG4 only because one a local gas station sells 89 as the same price of other places 87.
I was getting some slight knocks with 87, but my car is moded somewhat.in sig
I think the open air elements and uncoated headers in the summer time attribute more towards knocks then the octane levels.
