horsepower estimate?
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: automatic
can anyone who has done these mods please tell me what kind of power im making
89 rs 305 tbi lo3
k&n extreme air filter
4 in cowl hood
1 7/8 in longtube headers
straight pipes
180* stat
1 in TB spacer
3.73 gears
hollow cats
89 rs 305 tbi lo3
4 in cowl hood
straight pipes
180* stat
1 in TB spacer
3.73 gears
hollow cats
Car: 2002 Z28
do you already have the 1 7/8" long tubes on the 305 or are you planning to install them. You should definately step it down to 1 5/8", 1 7/8" is definately a HUGE overkill for a 305. 1 3/4" is even an overkill for a 305, even most 350s. That could definately hurt you low end power. I read that Lingenfelter said that a 305 should use 1 1/2" primaries until it is making 300HP.
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
yeah, 1 7/8" is way too big for a L03. I'd just get 1 5/8 with a full 3" exhuast all they way back. And don't worry about being around 200hp, cuz you're not. You maybe have 180-185. Gears don't give you horsepower, the open element and tbi spacer are good, just add an injector spacer and do the ultimate tbi mods and you'd have most of the intake side done. Throw on a chip and you will probably be around 200-210 hp, depending on the mileage of your car of course.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Do not use those headers. You will lose power with them. Plus how are you going to use dual cats with longtubes?
Anyways, swap those headers and complete your exhaust with a cat back and you are looking at 180 to 200 at the crank.
Anyways, swap those headers and complete your exhaust with a cat back and you are looking at 180 to 200 at the crank. With what you call Performance Mods??? everyone is being generous with the horsepower estimates. A 170Hp stock motor with what you added, not much more then stock. Sorry about that.
Car: '90 RS
Engine: 377 LSX
Originally posted by ShiftyCapone
A full exhaust and intake LO3 can put 200 to the wheels 90% of the time. Even the lowly LO3 was slightly underrated from the general.
I think the only true way would be to Dyno that Highly Modded 305 TBI. But no one want to spend money to be disappointed, they just want other people to guess for them (HP numbers)and take the highest estimates as it output.
Car: 91 RS
Engine: 350 TBI
Another DREAMER.........+30 HP with full exhaust, sure.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
DJP87Z28,
I was skeptical when I heard of the gains from an LO3 after a full exhaust swap, but I was proved wrong. It's not uncommon to see 180+ HP at the rear wheels after that mod.
Here's the link to show how skeptical I was...
https://www.thirdgen.org/techbb2/sho...ght=rear+wheel
Originally posted by AJ_92RS
DJP87Z28,
DJP87Z28,
Good Luck I never came close to those gains with SLP Headers and a complete 3" SLP Catback Exhaust with a 350.
So what is your point with that thread, gave up reading it after two pages.
Car: '90 RS
Engine: 377 LSX
Now its REAR WHEEL HORSEPOWER???? and 180 at that for a LO3
If you click on the links that 25thRS gave, you'll see the actual dyno charts that show that much improvement.
Or you can deny the fact that you're wrong. It's up to you.
Car: '90 RS
Engine: 377 LSX
Here is one of those links. This guy had only a full exhuast with the stock air cleaner assembly and made 178hp. I am pretty sure he has an auto car as well. His number would have even been better with an open element and T5.
https://www.thirdgen.org/techbb2/sho...ghlight=dynoed
Here is another guy that is running 14.7 with stock heads and cam.
https://www.thirdgen.org/techbb2/sho...hreadid=228134
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
Wow a tpi guy comeing and telling us gains with our motors. i find that quite amuseing mabey you dont get very good power because you useing a 350 with a 305 tpi setup. but thats beside the point just look at flowmaster they slap on exaust systems to car and get up to 30rwhp gains. proven rwhp is hard to argue but hey if you wana hate and doubt tbi be my guest.
Car: '90 RS
Engine: 377 LSX
Lets not turn this into a war. Everyone can have their opinions we will just have our dyno sheets. This is why I hate power geussing threads like this.
Heh. DOWN WITH THE POWER GUESSING THREDS! You shurely are right all everyone ever does with thred liek tihs is argue and in the end the starter hasnt learned anything but what he came in with.
Car: '90 RS
Engine: 377 LSX
dbrochard
Sep 25, 2015 04:56 PM
