What gaskets should I get for Edelbrock TBI Intake?
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I finally got my Performer TBI intake today and I need to get all the gaskets for install. What kind and basically what will I need to get the job done right? Also, my Edelbrock manifold has a couple little scratches in the polised part around the fuel injector bores...they are small and I can feel them when I run my finger over it. It isn't real deep though...should I worry about this, or will gaskets and sealer take care of it? Help!
Car: so many projects to little time
Engine: 350 tbi
just get a basic intake install gasket kit from the auto parts store. I sprung for the mr gasket set around 35.00\ 40.00 bucks. youll need rtv gasket silicone, some antifreeze...i drainded mine...made it less messy. thermostat and gasket.. i changed it all for good measure.. as for the scratches mine had a few small ones too and a regular gasket works just fine..
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't worry about the little scratches. f you are super worried just call the place that you bought it from and see if they will send you another one. I used plain GM replacement gaskets when i first put the intake on. I have now gone with a set of fel pro only because I had them lying around at the time when the intake came off again for the cam swap. You can use either. I have called edelbrock before on this matter and they do not recomend fel pro gaskets with the use of this intake for some reason.
Car: 1994 Chev K2500
Engine: Chev 350
Here is a link to the instructions from Edelbrock
http://www.edelbrock.com/automotive/...ral_instr.html
It mentions a little about what gaskets to use. I'm wondering though, how much rtv does everyone use? Do you use it on both sides of the gasket?
Car: 1992 Camaro RS
Engine: 305 L03
Thanks!
Thanks guys, when I'm ready to install I guess I'll just go to Advance Auto Parts for gaskets and rtv. I'm rebuilding my TBI at the same time and I already purchased the GPsorensen kit. Can't wait to get started! Anything else I should know?
Car: '90 RS
Engine: 377 LSX
Car: 2002 Z28
i recommend that you put sealant around the coolant passages front and rear. I put on my intake manifold dry, later i checked my coolant and there was oil in the coolant and i am assuming coolant in the oil so i had to rip everything off and do it over again. Even the Haynes manual recommends sealant at the coolant passages and there was sealant on the orginal intake gasket.
Car: '90 RS
Engine: 377 LSX
Engine: Chev 350
Originally posted by ShiftyCapone
vjo brings up a good point. I have had good luck putting them on dry but I think I am going to start putting some sealant around the cooling passages. You may also want to put a dab of sealant on the end of the intake bolts to keep oil from seeping up and pooling on your new intake. It is not a problem but only an eye sore.
Car: '90 RS
Engine: 377 LSX
Originally posted by 25thanniversary
did all of you feel a difference after u put the edelbrock intake on?
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
86IROC112
Aug 17, 2015 02:00 PM
