MAP or MAF Sensor???
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Hey everyone
This is a complete n00b question however I was wondering. Do TBI based engines have a MAP or MAF sensor? If so where abouts is it located.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
MAP
the sensor is located on the cowl, just above the pass. side exaust manifold, it gets its vacume signal from a tube that connects to the back-side of the throttle body.
anyone got a good pic of this just so I have a rough idea what I am looking for?
Car: 1990 Camaro RS
it is the only little black box, attached directly to the cowl. it is HARD to miss it.
Car: 91 RS
Engine: 305 Tbi (L03)
Hmm not sure how it would get dirty but a failed map sensor will cause lots of drivability problems. You could test it really easy by using a vacuum pump and a volmeter. You should get readings from 0-5 from atmospheric to about 20in of vacuum.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A dirty map will not affect the way your car runs. I bad one will because it will not give the proper readings to determin engine load.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
What makes you think its the MAP right away thrax? If your car is running rich I would check some other stuff out first. Make sure you get a nice cone from the injectors that's just good to check anyways. I would change the O2 sensor before the map if its running rich.
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
