engine build w/TBI
Old Apr 27, 2004 | 10:18 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
engine build w/TBI
I am getting ready to find me a 350 engine block and start building an engine. What im looking to do is get into the low 13's if possible by using my stock throttle body? Also i am wanting to keep the car fairly streetable. Can this be done, and if so what kind of heads and cam should i go with?
Old Apr 27, 2004 | 10:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is all going to boil down to chip tuning. You may want to look into a vortec set-up of some sort. You can get crazy power for a really low price. You are going to have to upgrade every part of your car that is associated with TBI. You will need a better fuel pump and larger injectors. You may have a hard time getting the most out of your new motor with the stock TBI unit.
Old Apr 29, 2004 | 09:56 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Thats what i was hoping with the vortec heads, i know you can get those fairly cheap. The deal with the fuel pump is no big deal, i have had to switch one out already so that wont be a big deal. So would you recommend using my TBI unit or going with something else? And also will i be able to keep my car streetable?
Old Apr 29, 2004 | 10:41 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
Id either do the port and polish W/all of the ultimate TBI mods, or Just save yourself the time and hassle by getting the hollet 670 TBI unit.
Old Apr 29, 2004 | 11:05 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
well this is what im planning and with what i have already im hoping for mid 13s with this depending on the cam i get. i got a complete l98 minus tpi for 125. it has 95 k on it when i bought it. its not a vortec head setup but its worth checking out if you can find a deal like I did.
l98 short block ...30 over
ported l98 heads
holley tbi intake
holly 670 tbi
comcams cam ???
compression aournd 10:1
#65 injectors
high fllow fuel pump
lots of tunning of course!!
Old Apr 29, 2004 | 11:47 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Don;t forget the suspension work!
The vortec and tuning would get you very close.
S-D
Old Apr 29, 2004 | 11:56 PM
steve8586iroc's Avatar
Why not build a high torque low rpm 383? If it's built right it would make gobs of torque where you need it most and still use the stock tb with 350 65lb injectors. I'd say if you could make 300hp and 400ft/lbs tq you would be right in the mid to low 13teens.
Just a guess, but I don't see why it wouldn't work. Just don't try to spin it to 6000rpm. If you didn't try to go past 5200rpm you probably wouldn't run out of air. With an engine that makes most of it's power down low you don't have to spin it to the moon to go fast. A good gear would probably be a 3.23 with a posi.
Steve
Old May 8, 2004 | 11:16 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I went w/ a LO5 long block with a mild Crane cam (204/214 .429/.452 116), Trick Flow 23* heads, a 2" Edelbrock TBI manifold, a 2" SBC TBI unit, 65# injectors, Hooker 2055's and a full 3" exhaust.
The Engine Builder Analyzer program spit out 385 HP and 430 lb/ft, but I don't know what that would be good for in the 1/4 mile. Everybody talks about using a bigger cam, but I think you'll get more by not cheating yourself on the heads.
I must of ran 30 combos through that program, and every time a change to the heads made much more significant increase in HP than a larger cam. Also, a larger cam will kill daily usage. As expected, I found the biggest increase by using AFR's 190 heads, but for the increase in HP over the Trick Flow's, I was running into diminishing marginal returns for the money.
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
