Tbi Question
Old Apr 29, 2004 | 08:19 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
Tbi Question
Can somebody give me a side shot of their TB so i can see where the detent cable goes?? I took off my cruise and i dont remember where the detent cable goes.
Old Apr 29, 2004 | 10:45 AM
89305RS's Avatar
Well then can anybody tell me if the detent cable goes on the top or bottom barb. Also i have an 87 or 88 trans in an 89 car. the detent cable i got was for an 87 car. It was the one closest to the length of the old one. Will this work fine? the 89 was like 3 inches longer than the 87 detent that came off of my car. Thanks-Joe
Old Apr 29, 2004 | 12:56 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
more pics on my site
Old Apr 29, 2004 | 01:59 PM
Ronny's Avatar
are the 305 and 454 TB common on the connections/cables? mine 454 is ready to install and i purchased an edelbrock adjustable throttle cable bracket. it came off 94-95 truck. would i use a camaro cable or truck cable? i was told i will need to cut or splice my cruise or lokar can do made to order? all i need is throttle and CC. no kickdown(manual).
Old Apr 29, 2004 | 02:22 PM
89305RS's Avatar
Thanks snuffy!!
Old Apr 29, 2004 | 05:32 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are going to have to do some fab work for the 454 linkage to hook up to yours. It is easier to cut off the plate from your stocker and weld it onto the 454. Chuck should have his tech article up by mid summer.
Old Apr 29, 2004 | 07:58 PM
snflupigus's Avatar
no its not easier if you dont know how to weld or own a welder... its easier to cut out a peice of steel, grind it to shape, drill holes and drill out your 454's linkage connections and bolt on your adapter for your kickdown cable.
now, is it cleaner and better looking and more stock looking, yup. more skill and care put into it, yup.
Old Apr 29, 2004 | 08:01 PM
snflupigus's Avatar
for as many tbi's as ive seen btw, there are many different linkages... this was a truck 454. no kickdown. i just made an adapter so that all was the same as stock.
i dont think you should have to cut your kickdown... if anything you can adjust it at the mount i think. just make sure that when you do put it together... it measures same as stock. try marking the cable with a marker or white pen and see the full pull out and full relax. check it on your new one... all good?
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
