Who makes the best adjustable pressure regulator?
Old May 8, 2004 | 01:16 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Title says it all. I've tried a Jet unit but the pressure couldn't be lowered to less than 12.5 psi which had my car running way too rich. I'm thinking that my car needs around 10.5 to 11 psi. The stock fpr has the car at 12psi and it just barely passed it's most recent smog test. Does Turbo City still make modified OE fpr units that allow you to adjust them? I'd love to be able to find one so as to do some fine tuning on the dyno with the fuel pressure to try and pick up a few horses. I've always thought my car ran rich though and maybe this will help.
Old May 8, 2004 | 01:57 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Go to the TDS link at the top of the screen. Ron sells one w/ a different springs that makes it easier to tune.
Old May 9, 2004 | 12:49 AM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
have ya tryed the DIY afpr? im surprised you couldnt get the Jet unit to go lower.
Old May 9, 2004 | 12:03 PM
Mongoose's Avatar
Car: 90 Formula
I thought about the DIY deal but I'd rather have one I can adjust on the car instead of having to remove the injector pod top to do it. I may try the Jet piece again since at the time I used it I had a Cyberdyne digital fuel pressure gauge that read all over the place. I now have an Autometer electric unit that reads way more accurate. I may give it another try this weekend. Anyone with experience using the TDS kit?
Old May 9, 2004 | 02:51 PM
Car: 91 RS
Engine: 350 TBI
Yeah, I got it, and I like it. But after installing the Walbro 190 fuel pump, I might have to put the big block spring in so I can get my fuel pressure down.
Old May 10, 2004 | 12:42 PM
Z28GEN3's Avatar
Engine: 305TBI
if ya look for the thread theres someone who has made the stock one adjustable and such that you dont have to remove it to +/- the pressure.
Old May 10, 2004 | 03:53 PM
Ronny's Avatar
aeromotive aei-13301 3 lbs to 20 or opt spring for 20-65. i have one. easy adjustment with allen wrench/lock nut. looks good too.
Old May 10, 2004 | 05:05 PM
Mongoose's Avatar
Car: 90 Formula
You got a pic of that on your car Ronny? How involved is the install?
Old May 10, 2004 | 05:28 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
I'm interested in what that looks like too.
I have just got done making a stock regulator adjustable. The one I have on the car is from a 350TBI unit, the one I modified was a spare from my old 305TBI. Do you think that the spring inside might be different for the 305?
Old May 10, 2004 | 07:38 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Here's pics of the regs themselves:
http://216.242.145.16/products/view....cat=Regulators
I use the 13101, as I had it on hand for another project. Plus I'm running some elevated pressures, and it has vac/boost compensation.
The 13301 also has boost/vac compensation, and would have worked as well for me.
I could only get a 6lb span with a GM reg, where I get 8 with the Aeromotive.
Old May 11, 2004 | 02:19 PM
Ronny's Avatar
mine is new in box awaiting install! i am mounting on the bracket that attaches to my alternator that used to serve the air pump support as well. i assume f bodies have similar stock bracket. i fashioned another bracket that has a provision (2 holes)for attach of the FP gauge as well as the regulator just to passanger side of alternator. all this is being installed (hopefully) next week with new cam, 454 TB on adapter plate, and WB02 sensor. i will take photos of the mods
Old May 11, 2004 | 10:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would look into getting the GM vacuum adjustable unit. You can run around 11-12 at idle and up to 15 at WOT. Adjusting our fuel pressure is only really a stab in the dark until you get into prom burning for proper fuel delivery.
Old May 12, 2004 | 08:02 AM
Mongoose's Avatar
Car: 90 Formula
I'm really looking to lean mine out a bit as it sits at 12-12.25 psi whether at idle or WOT. I'd like to get it down to around 10.5 to 11 mainly to see if that helps both the performance and the emissions output. I'm not concerned about PROM burning right now, plenty of time for that after emissions testing is dropped in 2006. A 350 crate motor is in the future for the bird but I still have to pass in '05 and my friend at the smog check helped me "pass" this time. Blew a 214 on a 220 scale, first time it has ever done this poorly but I didn't get a chance to do a thorough tune up before I went.
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Dec 11, 2016 09:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
