Speed buffer
Old Jun 9, 2004 | 08:50 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
Speed buffer
Will driving a tbi camaro with the speed buffer not hooked up cost horsepower. Because if i understand it correctly the speed buffer controls lookup, egr, and cruse control. Does the ecu use speed readings to contol like fuel ratios etc. Just wondering because i currently do not have my speed buffer hooked up.
Old Jun 9, 2004 | 09:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Do you mean speed limiter? If you bypass the VSS you will throw a code but will not have any drivability problems. The EGR and AF ratio are complete separate from any VSS signal.
Old Jun 9, 2004 | 09:58 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
http://www.hioutput.com/tech/speedo.html
This is what the speed buffer is and what it does.
This is for an electronic speedo
Old Jun 9, 2004 | 10:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I geuss I am still confused. Isn't that just a tech article to swap to an electric speedo? What exactly do you have not hooked up? Explain if you could.
Old Jun 10, 2004 | 08:12 PM
steve8586iroc's Avatar
Shifty, I believe he is talking about the yellow box that is on or near the ecm on all gm vehicles with an electronic speedo. I think his question would about having it unpluged would have the same effect as having the vss unpluged at the tranny.
Steve
Old Jun 10, 2004 | 09:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Steve
Thats what I thougth but I wasnt sure. I had never heard of speed buffer and wasn't sure if he meant that box, the VSS, the speedo gears or somthing else. What is that thing called anyways?
Old Jun 11, 2004 | 05:00 PM
Probably a speed signal buffer.
Steve
Old Jun 11, 2004 | 05:25 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
now i think you are on the right track. My question was about if i had the yellow box unpluged (speed buffer) would it cause drivability problems and would i loose power (horsepower torque etc.) I know the speedo wouldent work and the egr and lockup would not either
Old Jun 11, 2004 | 05:48 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
EGR will still work and so will all of your other engine functions.
Old Jun 12, 2004 | 10:52 AM
JokerRS's Avatar
Car: 92RS
Engine: 357
Shifty, I'm not sure what rout the ECM takes to get the information, but there are mph parameters for egr enable and dissable.
Old Jun 12, 2004 | 10:59 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You are complety right about the EGR. I have forgotten about that. Mine is set at the stock mph right now but will be set to 200mph or some un reachable speed to dissable it. You can tell its been awhile since I have been around a lap top. Should have the car tuned soon.
Old Jun 12, 2004 | 10:07 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
Better set it to 255 to be safe
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
J.C. Denton
Sep 21, 2015 04:23 PM
Randomtask2
Sep 10, 2015 08:37 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
