Part III, $500 TBI Build up...
well, iv just put my headers on, excepted one bolt on the passenger side fire wall "HARD"... iv done the FPR mod... now that i have headers i should move the fuel up to 15psi? what would be a good PSI to run? also will the EMC "computer" try to make it a different A/F
and what about the 02 sincer? well anything get messed up?
its kinda confusing...
and i busted one of the knock sencers on the passenger side, thats what it looks like
do i even need that? besides running a code, it wont mess anything else up?
i also found this in the garage when i was cleaning ... its been in are garage for a few years, FREE BE!!! im planing on bumping up the timeing and also
going to make SFC's, and STB.... shouldn't be more then $40
what else could i make will im at it? that's a for sure....
my next buy, might be the PROMinator $275
witch means the build up needs more funds...
but im not sure yet...
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The coil in that picture won't work. Who has those kind of parts laying around anyways.
You will need an 02 sensor if that is what you were asking. You also most likely busted the fan switch on the passenger side head. Your fan will constantly run now. I would change it now while you have the coolant drained. It is a $10 part. So what is part III? What exactly was part's I and II besides an education on parts selection
Car: '90 RS
Engine: 377 LSX
Originally posted by NEEDforSPEED
why a new 02?
anyways, what anbout PSI? anything else i need to ajusted?
why a new 02?
Car: '90 RS
Engine: 377 LSX
Shifty, have you heared about the PROMinator?
if you had whats your thots about it... im realy looking into it...
Car: '90 RS
Engine: 377 LSX
would it be worth getting? tho?
Car: White KSwisses
Engine: 5.3L Gen III
Re: Part III, $500 TBI Build up...
I think u should replace it. If you are getting any kind of knock, that think saves your engine. Knock counts are a valuable thing to look at once u get started tuning and playing around with timing...
Edit: okay, i didnt realize how old this thread was, but it still applies.
Car: '90 RS
Engine: 377 LSX
Re: Re: Part III, $500 TBI Build up...
Originally posted by cali92RS
Did i miss something? Why didnt u address this, shifty?
