okay, now I am confused....
Old Jul 1, 2004 | 09:38 AM
matching#s's Avatar
Car: 89 rs convertible, 99 Tahoe custom, 71 RS/SS 350 camaro (in restoration)
Engine: 305, 350, & 383 stroker
Transmission: 700r4 & Th350
So here it is. I was planning on doing the holley 670 conversion on my 89 rs droptop with a 305 tbi. I need to get a little more out of her. So I was told that I needed to bore out my manifold because the holley TBI is 2" in diameter. Well I got all my parts in; the holley tbi, bored manifold, new coil etc. Well I decided to measure the throttle body and my new bores on the manifild and guess what? The throttle body is only 1 11/16" in diameter. Not the 2" as I was told it would be. What do I do? Should I simply install the holley on to my stock manifold? Could the discussion have gotten confused with instaling a 454 throttle body? Have I been sent the wrong throttle body? Thanks for your help everyone. Have a great morning!
Bob
Old Jul 1, 2004 | 09:43 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
do you have a picture of the TB unit.
i assume if there is doubt, you did not buy this unit, new from holley. Is it even a holley TBI unit? 1 11/16 is the stock small block TB bore. the 454 units have 2" as do the holley units.
Old Jul 1, 2004 | 10:16 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A pic would help. There are plenty of physical differences between the 454, stock and holley units to tell them apart. Chances are if it looks exactly like your stocker than you were duped.
Old Jul 1, 2004 | 10:19 AM
matching#s's Avatar
sent a pic
Thanks for the help Dewey_316, I just emailed you the only pic I have of the thottle body. I'm not sure how to post pics on this sight as of yet. It's is deffinately a holley TB. Holley is printed in the casting of the TB. Maybe this is for the s-10 V6 or something? Seems like this will simply bolt right on to what I already have, but would the performance change at all? Am I looking to purchase a different throttle body? So close, yet so far away! Thanks for any help you can give me. have a great mornging my friend!
Bob
Old Jul 1, 2004 | 10:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
what type of file is that, i can't seem to open it.
Old Jul 1, 2004 | 11:11 AM
matching#s's Avatar
sent a new one
I just sent you a new one my friend. I made sure that I sent you a jpeg. I apologize. I'm not sure what format the original was sent in. I am roaming today, meaning i am using everyone elses's computer but the one in my own office. I'm currently on a Mac with OS 10 and it obviously does not save pics in jpeg format by default as does a windows machine. Sorry for the frustration. Thanks for the help!!
Bob
Old Jul 1, 2004 | 11:33 AM
Ronny's Avatar
HOLLEY 400 cfm 1.68 bore size. 2.8L v6 replacement. supports 123 HP at 6000 rpm.
670 cfm is 2.00 inch.
TPI_BLAZER
Jan 9, 2013 12:24 PM
hzemall
Dec 23, 2008 06:38 PM
naterman35
Jun 29, 2007 08:43 AM
kaptinkafeen
Jan 8, 2007 10:37 AM
92zcamaroperson
Brakes
Jun 23, 2006 11:29 PM
