tbi to stealth ram
Car: 1992 camaro rs 25th anniversary
Engine: 305 tbi
Transmission: 700-r4
tbi to stealth ram
hey everybody, i just wanted to know if it was possible to swap a holley stealth ram system on my 305 tbi, if anyone here has done it and if they can give me some tips and also if it is expensive or not.
thanks
thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is very possible but serious overkill for your 305. You may actually lose power. You would need a healthy set of heads and cam to take advantage of it. it is best suited for 350+ CI engines. The first thing you would have to do would be to convert to a complete multiport set-up. That will drive the cost up big time since you are not starting weith TPI and would need every little bit of wiring and such. By them time you get done, you could have a 350 or larger with TBI probably making more power.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Nope. Not at all. Better to stay with what you have because at this point switching what type of fuel injection will not give you any power increase. Fix what needs to be fixed with the motor first. The motor's downfalls are tiny exhaust, horrible heads, horrible cam and restrictive manifold. Fix those first and make something over 170 horsepower and then maybe worry about induction.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Originally posted by glintscollide
very good advice and i thank you for it.im in the same boat,tbi 305 no exhaust headers yadayada.Imma work on tbi setup then maybe convert.Anyways TGO ****IN ROCKS.LATER
Like you, I entered this forum with high hopes for my 305 not knowing any better. At this point and considering the use of my car, the 305 gives me what I need:
- Torquey throttle response
- Decent gas mileage for a V8
- Rumbly exhaust
- Reliability (comes with proper maintenance)
Car: 1991 Camaro Z28
springfield,
Hey I am thinking of doing a fuel injection swap sometime, but I am thinking of switching to the edelbrock pro flo or the holley commander 950. I had a 305 and am currently droping the 350 in. After i save some more money I will upgrade the cam and heads and then go with the aftermarket fuel system. But like everbody else says don't put it on the 305. I mean I probably would switch over on a 305 if i wanted to supercharge it or something just for ease.
Just my 2 cents
Bill
Just my 2 cents
Bill
rs_z28_vert
Sep 30, 2015 09:47 PM
