New help with new throttle body
Old Jul 17, 2004 | 01:40 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I'm putting on my new 2" throttle body today, but I've noticed that it is slightly different from my stock unit.
On our stock units, we have 4 vacuum ports on the front of the body, but my new one has 3. The one that's missing is the one of the far right (driver's side). Now, IF I remember correctly, that port went to the VAFPR????
So, what do I do now? Can I just put a t-fitting on the port on the passenger side and call it a day or what?
Thanks guys.
By the way, I know I haven't been posting much lately. This engine swap is taking FOREVER!!!
Old Jul 17, 2004 | 02:52 PM
steve8586iroc's Avatar
See if this helps. Look At this thread. It's the second post from the bottom.
Steve
Old Jul 17, 2004 | 02:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You can tee anything except the MAP. The other accesories wont be bothered by having two things hooked up to one vac port.
Old Jul 17, 2004 | 02:59 PM
Car: 91 RS
Engine: 350 TBI
Thanks Steve.
Well, since I removed the air cleaner housing a long time ago, I think I plugged that port until I got my VAFPR, the I plugged it into there. I would think that since it's for my FPR, that it would be wise to have the vacuum source come from the throttle body?
So which port should I put a t-fitting into in order to operate it? Or does it really not matter at all (eg could I just plug it into the brake booster or something)????
EDIT: Dimented post while I was typing this
Old Jul 17, 2004 | 05:33 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Id say the egr if you had to t into something. Its a realatively low load and there isnt any gas or oil going through it like the can or the pcv, not to mention that the vacuum feeding the pcv will fluctuate alot. See if you can use a larger line to feed both the VAFPR and the egr. Should help keep vacuum fluctuations down to a minimum when the egr is activated.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
