vafpr
Car: White KSwisses
Engine: 5.3L Gen III
http://www.top-downsolutions.com/
This is the only place i know where u can get everything u need for a vafpr. Plus, i know Lon he's a cool cat.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I got mine from GM parts direct and got the spring from lon at Top Down Solutions along with some instructions how to use it. I got the delay valve from napa. It is much easier to buy the whole kit from him. When I bought it he did not have the kit available yet.
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
i ordered the whole kit from top down, its coming on wednesday, where did you hook the vacuum line to, and do i need a fp gauge to adjust it?
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
is it nessecary to run the line through the tbi unit, is that how im gonna have to run it?
It is not as easy as you think to route it out of the way. The vacuun line is stiff and is not easy to work with. Also, you have to contend with the open element, spacer ring (if equiped), and the long vacuum main comming out of the regulator (I alread bent it to better accomodate). I have been too lazy to redirect it in another mannor. Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
how can i bend the main without crimping it
Axle/Gears: 3.45, 3.27, 3.27
I used a straight piece of slightly larger diameter tubing over the end of the tube to be bent, kind of like a mini "cheater-bar". As SC mentions be carefull. I held the short straight portion with a long nose plier as I un-bent the fitting.
Some people just cut the fitting shorter beyond the bend. I routed my vac line as shown. I drileld a hole and used a 1/4" drive socket and handle to bend the hole in the spacer so the vac line conforms to the wall as flush as possible.
Lon
Lon
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Cut the bent part of the fitting off of the fpr.
Go to AutloZone, etc and buy some 90* vac fittings.
I used some of the hard plastic lines that were left over from EGR removal etc.
Using a dremel tool, open up the rear of the TB where the fittings screw into the injector pod. Open it just enough to fit your hard line thru.
Install the 90* fitting on the fpr and route the hard plasic line out the rear of the TB beside the fuel fitting. Cut off the hard plastic line and splice on rubber vac line of choice and route as needed.
This way, none of the airflow is obstructed with hose, etc.
Or, you could just route it out the bottom of your air cleaner and not need to dremel the TB.
I need to get some pics of my TB up (when I get the camera!).
Car: '90 RS
Engine: 377 LSX
fadetoblack
Jul 24, 2006 12:02 PM
