Help! Car won't idle
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are going to have to refresh me on the state of tune of your car along with how many miles are on it. Also, what have you outruled from the time you had this problem.
Car: '90 RS
Engine: 377 LSX
Originally posted by johnjm22
While the power was still out I decided to check my battery connections. While I had the positive cable disconnected the underhood light suddenly came back on. Is it supposed to do that? I thought you couldn't have power if the positive cable wasn't conected.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
Okay I was a little confused on that one. I had the small wire that went to the positive terminal disconnected, not the main one.
But yeah, I recently cleaned the terminals and everthing with a dremal tool using the wire brush attachment. They are very clean.
I just don't understand why the power cuts out when I try and start it, then it randomly comes back on by itself.
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro RS
Engine: 305 TBI
Well I don't know why the timing would be off. Like I said after I put the distributor back in place the car ran fine. It wasn't until about a month later until I started having problems. But I will check it.
So you don't think these two problems are related?
Car: '90 RS
Engine: 377 LSX
