freak of l03 goes back into action!
Old Aug 18, 2004 | 01:08 PM
Ann.racer92's Avatar
Car: 92 Camaro Heritage RS
Engine: 5.0
well, most of you guys read the post on my first run at the track a couple of weeks ago, and because of how i did that day they had me work, they hired me which means i can basically run test runs like once a week for free! im going there next week and ill be trying to get to the mid 15's with her.
since the last run i've modified the car a lil.
i put on an open element aircleaner and swapped out my coil which was rusting and had plates falling off of it for the one off of my parts car which was in fine condition, i pulled the throttle body and cleaned it pretty well and i've been practicing manual shifting with the tranny. seems like the carpulls harder in every gear!
what do you think ill run. place your bets guys! last run was a 15.9 at 84 mph and you can see what ive done. ill give the guy who gets the closest guess some goofy title, heck yea.
Old Aug 18, 2004 | 01:35 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Don't know if you are doing this already or not, but I know a lot of people don't think to do it. Drive with 2 feet, you can brake torque your car off the line to get a better launch. Good luck with your goal.
Old Aug 18, 2004 | 01:37 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i give a 15.6 @ 86 mph.
btw, i went 15.5 @ 90 and no traction, with a stock LO3, open element and computer work.
Old Aug 18, 2004 | 02:35 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would say mid 15's with a little practice. I wouldn't say you have a freak of an LO3 though. 90RS305 ran a 15.3 bone stock.
Old Aug 18, 2004 | 02:36 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
I say 12.34@115
Old Aug 18, 2004 | 11:00 PM
Engine: 5.0
i know its not a freak but thats jsut what everyone knew it as originally. im hoping for a 15.6. car seems to be pulling alot harder now with the open element and the newer coil. and yea im driving with two feet. the other thing im thinking is that putting it in drive vs overdrive and also trying manual shifting. more intersted in the drive thing though. that may sound stupid but im thinking with the 2.73 ill be able to gain mph and cut time by going higher in the rpms a lil and saving time on a shift. we'll see where its trying to go into overdrive at and make the decision
Old Aug 19, 2004 | 12:25 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
It doesn't matter, at WOT your transmission will not shift into overdrive no matter what.
Old Aug 19, 2004 | 07:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Ann, there are a couple of items that are nice to know about the 700R4 transmission. As BronYrAur mentioned the stock trans will not upshift to OD at WOT. I say stock because there are modifications that can be made to change the shift characteristics.
Manual 1st will not hold 1st. The trans will still upshift to 2nd even when held in manual 1st.
Manual 2nd can be held to any RPM.
Manual 1st and 2nd use a different boost valve that increases the line pressure.
This being said starting at the line in manual 2nd has advantages.
There is a forced TCC lookup at a preset MPH. This is controlled by the ECM. Usually done around 75 MPH +-.
RBob.
Old Aug 19, 2004 | 01:18 PM
Engine: 5.0
someone has toyed with the car before. it will hold first for me and it will also go into overdrive at WOT. i just did 110 the other day and it wasnt in the orange band on the tach yet. ill check for sure but im pretty sure that it will do those things. if it doesnt i will be surprised. what are the conditions for it to hold 1st or not hold 1st? i often play around with it on the way home from work especialy when im at lights and i want to kick the *** around some. i put it in 1st to do, ehem, practice for emergency situations where i need to swap directions . this car has been tinkered with for sure. we're pretty sure that it has a cam in it because the cover has obviously been pulled before but we cant say for sure. its been programed to run with a 160 degree thermostat among other things. it wouldnt surprise me to find someone had messed with the tranny because it had at least had the filter changed very recently when we did the tuneup and someone had pulled the governor cover before. too bad there isnt some way to find the original owner bet he'd like his car back! dude my name is dave, how do i change that stupid screen name so people dunt think im a chick!
Old Aug 19, 2004 | 01:38 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
The best I got out of mine before I opened up the engine was 15.0@91mph. That was with open air element, headers w/ full exhuast and 3.42 rear gears.
Old Aug 19, 2004 | 01:51 PM
Engine: 5.0
with headers and a full exhaust which is hopefully going in this winter. along with tuning and maybe some lca's im hoping to hit a 14.9. perhaps insane but i have some other things in the works. got some freinds at a machine shop who are going to work over a tb for me and im hoping to instal a vafpr as well as dump my ac and smog equipment. planning on getting a laptop and prominator as well.
Old Aug 19, 2004 | 01:52 PM
Engine: 5.0
dude you're in columbus? do you race at 42 or norwalk because WORK at 42
Old Aug 19, 2004 | 07:05 PM
getdrugtoday's Avatar
Car: 75 nova 11.15 @ 125, 92 1500 14.60 @97, 95 integra 15.80 @ 91
Engine: 377, 355, 1.8L
Transmission: t350, 700r4, m5
nice
i ran a 15.8 with a stock integra 1.8L NO V-TECH DOHC 128xxx. i know you dont care, but just wanted to pick on you.
Old Aug 19, 2004 | 08:26 PM
sunset92's Avatar
Car: sunset orange 92
Engine: 5.0
Transmission: t-5
my wifes 97 camry runs a 16.5 from the factory and it is a 4 banger...hee heee heeee
Old Aug 19, 2004 | 08:33 PM
haha!!
thats pretty funny. i hate to see how much faster we'd get if we did half the things to our our cars (integra, camry) like we do to the other ones!! may make me throw rocks at it lol
Old Aug 20, 2004 | 07:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Dave, sorry about that. As for changing the screen name I don't think that I can do it for you. You may want to register another name and drop the old one.
As for holding 1st gear a TransGo reprogramming kit will do it. This kit hijacks the 4-3(?, maybe the 3-2 setup, can't remember) downshift setup valve and converts it to a 1-2 manual upshift valve. It works.
RBob.
Old Aug 20, 2004 | 10:00 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
PM the admin or make a post in the help forum. He will be glad to change it for you.
Old Aug 20, 2004 | 10:10 AM
Axoid's Avatar
Car: 92 Camaro RS
A 14.9 is doable. I venture up to Norwalk with the local club, but drag isn't really my thing. My car is tuned for turning, my 60 foots range from 2.4 to 2.6.
Twice a year our local F-body club rents out Norwalk. The next one is in mid October. Check www.cofba.org if you want details.
Old Aug 20, 2004 | 10:17 AM
Axoid's Avatar
Car: 92 Camaro RS
Re: nice
I'm happy for you, my stock Saturn SUV runs low 15s.
Old Aug 21, 2004 | 03:52 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I'm gonna guess a 15.8 at 85. Type hoding it till just past 5K and def. try to torque brake her to get the RPMs up at the line.
Old Aug 21, 2004 | 03:14 PM
Poncho Villa's Avatar
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
Pretty sure my 700R4 will hold first. How far does it have to wind out before manual first shifts to second?
I can't wait to get a shift kit, or drop in a T5 or T56. Although I'm sure that part of the reason my motor is in perfect shape, is the automatic's grannyshifting tendencies.
Also, I never rev the motor past 3500 rpm, never, even though I'm sure the motor could handle it. Even so, I want to get a shift kit, and a Vette governor for crisper gear changes. Just in case some guy in a Saturn SUV needs his a$$ beat.
Old Aug 22, 2004 | 12:32 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
If I remember right my buddy with a stock lo3, 2.73, 700r4, only had to shift once. first to second, I could be wrong on that though.
Old Aug 22, 2004 | 05:39 AM
Pretty durn sure my tranny will hold first until the cows come home, or pop through the hood. I have wound it out in first, and it doesn't shift until I put it in second, with a nice shift actually. From second to third, the clutches take longer to hand over power, not slipping, just fluffing around in grand auto fashion. I go from 1, to 2, to D, whenever shifting manually, which is almost never.
I've heard the shift kit, eg. Transgo, and the Vette governor, give crisper and more satisfying shifts. Also, a ratchet shifter will prevent an overzealous amateur racer from sliding into "R for Racing" in the heat of the moment.
So a shift kit and ratchet shifter are on my wishlist. Then down the road, I want to be rowing the gears with a T56, running LS1 power...
Old Aug 22, 2004 | 07:38 PM
Engine: 5.0
post came alive in my absence..
sorry to argue with anyone about the overdrive at WOT thiung. you were completely right and everytime i test that im reminded of just how pathetic the top end on these cars is. 2.73's and im creeping past 100.
Old Aug 25, 2004 | 11:24 AM
Intensity_Z's Avatar
Car: 84Z/ 87 S-10
Engine: 355/350
Transmission: th-350/700-r4
[QUOTE]Originally posted by Ann.racer92
[B]someone has toyed with the car before. it will hold first for me and it will also go into overdrive at WOT. i just did 110 the other day and it wasnt in the orange band on the tach yet.
umm my bone stock l03 withj 273 gears will do 110 without hitting the orange either, its the gears at allow this, it won't peg out until i hit 120 (about 5000 rpms) and won't shift into over drive, if it did it may drop maybe 3-500 rpms
but a dodge durango r/t will actually shift into 4th gear at 120 mph that was the strangest experience for me
Old Aug 27, 2004 | 01:18 AM
Ya man, same here, my LO3 TBI pulls past a hunge no problem, and have had it at 115 with lots of pedal to go. Didn't want to push farther though, because I'd just gotten the car, and wasn't sure what kind of shape everything's in. No OD though. Won't do any Top Gun stuff until I have suspension more dialed in, and the motor thoroughly tuned. Still pulls hard at 100 mph, nice and smooth. Loves it.
Wondering if my car has a governor, as some did, limiting them to 115mph. Anybody know? 1991 Firebird 305 TBI.
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Apr 30, 2019 12:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
Fronzizzle
Aug 19, 2015 01:36 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
