So how do ya like purple?
Old Sep 25, 2004 | 04:33 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Picked this up from TonyC. Not exactly the same color as the purple haze but it is definitely purple. Should be going on next week.
Old Sep 25, 2004 | 08:07 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Looks good. Although the edelbock TBI intake may not be the best chose, it wins hands down in the ease of installation category. You may want to drill and tap the front AC bracket support now before you get it on the car. If not you risk breaking off an accessory bracket bolt off in the head.
Old Sep 25, 2004 | 08:56 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Shifty's right. I've been there before and it's not fun.
Yep, it's purple alright. How many purple RS's are there here. I'm one, your one, who else?
Old Sep 25, 2004 | 10:25 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Don't hate me, but I think purple only belongs on Mopars.
IMHO of course.
Old Sep 25, 2004 | 02:55 PM
azvolfan's Avatar
Shifty,
I not sure I follow you on that. The front a/c bracket?
Old Sep 25, 2004 | 05:35 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by azvolfan
Shifty,
Not the bracket but the brace. It attaches from the back of the AC compressor and bolts to the front of your intake. The Edelbrock intake has a provision for it but you need to drill and tap it out. I didn't at first when i got my intake and I eventually broke an accessory bracket bolt off in the head. It was a mess. I immediately drilled and tapped it then. It is really easy to do and you can tap it by hand with an over the counter kit at any hardware or automotive store.
Old Sep 25, 2004 | 05:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here is a pic that I dug up that shows the intake as it comes. I have since put a bolt in there to prevent any more borken bolts.
Old Sep 25, 2004 | 09:26 PM
Benm109's Avatar
Engine: 305 TBI
I'm not sure if you have the instructions or not, but it tells you what to do in them. But, just in case you don't have the instructions, it just says to drill a 5/16 hole 1-1/8" deep and then tap the hole with a 3/8-16 thread tap, 1" deep. Hope this helps.
Old Sep 25, 2004 | 09:34 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Doesn't that intake get hot? What kinda paint did you use that will withstand heat?
Old Sep 25, 2004 | 09:36 PM
Benm109's Avatar
Engine: 305 TBI
From the looks of the can I would say engine enamel. Most of these paints can withstand about 500 degrees F. You can get it anywhere, Wal-mart, Autozone, etc, and in all sorts of different colors.
Old Sep 25, 2004 | 10:55 PM
azvolfan's Avatar
Yep, its high heat engine paint. Put on some primer and then the purple.
Shifty,
I think I already have that on the intake. tonyC must have put it there. I know the hole is there. I have to check and see if it is tapped.
Old Sep 26, 2004 | 01:26 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Yeah, it's there, you got a better pic on the S/W region board...
This should be a fairly easy swap to do. Ya know Bill, you might as well (if you haven't already) get a 160* therm. and some new radiator hoses just to get em' outta the way...
Bruce (90RS305)
Old Sep 26, 2004 | 02:08 AM
azvolfan's Avatar
Those have already been done. Good idea though.
Old Sep 26, 2004 | 08:02 PM
25THRSS's Avatar
I really like the purple on your car, but not that purple on the intake manifold. Good choice on manifold, bad choice on paint.
Old Sep 26, 2004 | 10:52 PM
azvolfan's Avatar
Well it kinda turned out a different color than I thought it would. But I can live with it.
Old Sep 26, 2004 | 11:01 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Dont you hate that? Buy paint of one color and it dries to another color after youve applied it.
Old Sep 27, 2004 | 03:02 AM
azvolfan's Avatar
Actually if you look close, purple haze does infact have a bit of lavender in it. It's not very pervasive but it is definitely there.
Old Sep 27, 2004 | 05:52 PM
90_WS6_Formula's Avatar
Car: 91 Z28
what color primer did you use? I'm pretty sure black primer or even the red primer would have yeilded a richer color.
Old Sep 27, 2004 | 07:38 PM
azvolfan's Avatar
It was a gray primer.
Old Sep 27, 2004 | 08:11 PM
Car: 91 Z28
is there any way to redo it before Friday?
Old Sep 27, 2004 | 08:43 PM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Man thats looks alot like Chevrolet Blue. i painted my engine bay, intake, and a few brackets that Chevy Blue and I swear thats what your intake looks like....course I could be colorblind
Old Sep 27, 2004 | 09:13 PM
90RS305's Avatar
Originally posted by TBI92Camaro
...course I could be colorblind ...
I'd say, thats about as purple as purple gets...:werd:
Old Sep 27, 2004 | 09:28 PM
steve8586iroc's Avatar
Get a can of candy apple blue and spray it over the lavender it might just look deep purple.
Steve
Old Sep 27, 2004 | 09:30 PM
ThraxXx's Avatar
Thats sweet. I am gonna have to get me some candy apple red and do some of my parts in the TransAm.
Old Sep 28, 2004 | 01:47 AM
90RS305's Avatar
Steve
Man....that actually sounds like it might look perdy dang sweet! Get a piece of metal and try that Bill!!
:rockon:
Old Sep 28, 2004 | 03:37 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Might want to try a hobby store. Sometimes they stock paints that are semi-transparent. Any other type of paint with a high opacity may just completly cover the lavender if its put on too thick.
Old Sep 28, 2004 | 07:24 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I painted my block with that same paint and it doesn't look THAT purple.
Well... maybe it does.
It doesn't look that girl-ish in person.
Old Sep 28, 2004 | 11:27 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
That hole was in there when I got it, JR305 must have put it there
Old Sep 29, 2004 | 01:45 AM
90RS305's Avatar
Wow, this intake has been around the block, huh?
Old Sep 29, 2004 | 02:47 AM
azvolfan's Avatar
Forget Fel-Pro, I need a gasket from Trojan.
Old Sep 29, 2004 | 03:18 AM
90RS305's Avatar
Hotrodboba400
Dec 10, 2019 07:07 PM
3rd gen money
Oct 11, 2019 09:57 PM
Elephantismo
Feb 13, 2019 12:51 AM
Cleotiz
Sep 16, 2015 08:02 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
