Sorry, intake question
Old Oct 8, 2004 | 05:08 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
For this who have swapped intakes, how in the #^*^%$!!! did you get the bolts on the back of the intake off? For example the 1 holding the throttle linkage bracket thing and the one next to it. I can hardly get a wrench on them, much less have enough room to get them off. This is really frustrating and I keep stepping away, getting frustrated again over and over. Any brilliant advice will probably save my car from destruction...
Old Oct 8, 2004 | 05:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
IIRC, I used an extention and u-joint to get to them with a socket on my LO3.
Old Oct 8, 2004 | 05:33 PM
Car: 1990 Formula
I must be thinking of a different part than you, how would you use a u joint with a ratchet? And don't extensions give you less torque?
Old Oct 8, 2004 | 10:20 PM
Car: 88 Camaro SC
Engine: SFI'd 350
As long as teh angle isnt really accute when your using a u-joint you wont loose any torque. The extention just allows the ratchet to be farther away so you can turn it. Basically it was socket (and maybe the u-joint), extention, and then the ratchet. Some things just work better then others so try all your tools.
Old Oct 9, 2004 | 03:26 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
First thing, try to calm down, you can do a lot of damage to things when you get angry Second, when I swapped my intake, I took everything off I could that was in the way of the back bolts that hold the throttle bracket and EGR selonoid. So first, remove the plug wires, distributor cap, and coil. Then disconnect the throttle cables and set them out of the way. Now, you should be able to fit a ratchet with an extension on the bolts holding the bracket down. Now, take the same approach to the other side that is holding the EGR selonoid bracket. Make sure you lablel all hoses and bolts and brackets...LABEL EVERYTHING to make an easier time putting it all back together. Good Luck!
Old Oct 9, 2004 | 11:18 AM
Car: 1990 Formula
I always know when to step away when I feel like smashing something with a hammer, I've stepped away from this project many times already. I'm gonna try to find a way to remove more things around it to give me more room and I just went to Sears to increase my arsenal a bit. Well here goes nothing...wish me luck.
Old Oct 9, 2004 | 11:45 AM
Car: 88 Camaro SC
Engine: SFI'd 350
If you havnt already, take out the dist. Youll never get anything out with that there. Without the dist., you could have more room to work.
Old Oct 9, 2004 | 05:36 PM
Car: 1990 Formula
Distributor is out, along with everything else except for one large bolt thing in the back left with a hose coming out of it. Can't get it to budge, aside from that there is nothing keeping the intake on. Should be off tomorrow and then I can start trying to get everything back on and hope that I can get her to run...
Old Oct 9, 2004 | 06:55 PM
Car: 88 Camaro SC
Engine: SFI'd 350
That sounds like the heater hose fitting. That things a major pain to get off. Leave that for after you get the intake off.
Old Oct 9, 2004 | 07:40 PM
Car: 1990 Formula
It sure is being stubborn...I saw some red on the threads, is that some kind of loc-tite? I know blue is medium stregnth so I thought maybe red was either weaker or stronger. I really hope its not ultra stregnth...
Old Oct 9, 2004 | 08:02 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
I've got a 1' extension and a 4" extension, threw em' together, and it was a sinch to get em' off. No elbow necessary.
Old Oct 10, 2004 | 12:40 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Formula,
The fitting you are talking about is the in fact the heater hose fitting. That is a biotch to get out, you need to go find the correct 1/2" socket that fits it (I forget exactly what size) and either have somebody hold the manifold or you stand on it while you torque that thing out with a 1/2" ratchet. I did that and then bought a chrome fitting from pepboys. Good Luck!
Old Oct 10, 2004 | 04:34 PM
Car: 1990 Formula
Well I got the intake off, which was interesting cause there was a bolt we didn't notice so me and my friend sat there wondering why it was being so stubborn Then when we pulled it off some coolant from the intake kinda spilled onto my engine. Will this have any horrific effects on my car? We put on the gaskets and rtv and rested the TBI on top of it and called it a day. Gonna buy some new bolts tomorrow cause the ones we pulled aren't looking too nice.
Old Oct 10, 2004 | 05:32 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
you should have swabbed up the coolant with a shop towel or some paper towels and then went on your way if you didnt you will just need to change your oil after you get it fired up and run it for a while ...all honestly as long as you didnt dump very much in there ....as long as it was just a little splash it wont hurt anything ....but i would change the oil anyway ...
Old Oct 10, 2004 | 06:31 PM
Car: 1990 Formula
We did clean it up with some paper towels, and I plan on changing the oil as soon as I finish getting everything hooked up. Aside from that things are going fairly well, slow, but well...
Old Oct 10, 2004 | 06:33 PM
THEGENERAL's Avatar
i hear that .....LOL
i just blew the engine in my truck and am in the process of switching engines from a donor truck i purchased to my truck ...LOL
Old Oct 11, 2004 | 01:29 AM
90RS305's Avatar
Good plan, but make sure you run your engine for about 1-2 minutes before you change it, that way the coolant mixes in with the oil and comes out when you change it. Make sure you change your filter, too!
Bruce (90RS305)
Old Oct 11, 2004 | 02:20 PM
Car: 1990 Formula
When putting the bolts back in, is it absolutely necessary to get each bolt in the same hole? If so I have a problem since all of my marking managed to get rubbed off. I was thinking I should just go to sears and put on some new bolts with some kind of teflon thread sealer.
Old Oct 11, 2004 | 02:36 PM
THEGENERAL's Avatar
you mean on the intake ???
doesnt matter the order unless one has a stud on it or something to mount a bracket too ....
i just throw a little silicone (form-a-gasket) on the end of each bolt before i thread it in ...
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
