need help quick ! manifold too tall.
Old Oct 18, 2004 | 09:59 AM
Ronny's Avatar
holley projection with 7.4L GM TB with edelbrock billet oval AC.
mocked up without gaskets it hits hood slightly(84 vette).
option #1 is to mill manifold top surface. costly? pick up 1/8 inch. may not be enough.
option #2 is to mill the top of AC and remove the pretty groves plus not use the large knurled plastic nuts. use a flat nut or acorn nut.
option #3 is to use flat aluminum plate with acorn nut 1/8 inch thickness.
keep in mind had to use oval AC to clear the throttle linkage. a flat AC hits linkage and a spacer would not provide any clearance. drop hits linkage as well.
any ideas??
Old Oct 18, 2004 | 11:40 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I actually bent the bottom flange on my air clearner in order to tilt the air cleaner forweard. This allowed everything to clear. Depending how your ac is hitting and what it is made out of it might work. I just pushed really hard on one of those cheapy stamped steel cleaner bases and the little lip that actually seals to the TB bent over and gave me the clearance needed. If you want you could trim that lip down or even at an angle to do the same thing I did with my getto rig aproach.
Old Oct 18, 2004 | 12:08 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Is this air cleaner one of the cast aluminum ones? How much clearence do you need with a standard air cleaner? I got some extra clearence around my holley pod by beating one of the cheapo sheet metal ones with a ball peen hammer to round it to the right shape.
Old Oct 18, 2004 | 12:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can also screw in the intake stud a bit to help the wing nut clear.
Old Oct 18, 2004 | 12:35 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
This worked for me in getting clearance for a non-drop OA element. The problem now is the stud is now getting stripped. This part appears to be discontinued by GM parts.
Old Oct 18, 2004 | 12:44 PM
Ronny's Avatar
thanks. found a summit AC that is oval. 3/4 inch shorter top/bottom. 2.75 vs 3.5 inch. the only issue with that is clearance to pod on the TB. we measured about 3/4 inch to pod to edelbrock bottom of air cleaner top. this summit will cut it close but give me room so hood does not rub. with edel in place it barely touches.
Old Oct 18, 2004 | 12:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I'm going to assume the $250 low-pro holley air cleaner is not an option?
Old Oct 18, 2004 | 01:07 PM
Ronny's Avatar
absolutely. saw it at summit. actually i gained some clearance this noon by removing a "tang" hanging on throttel linkage on TB. the summit i referenced is wider than edelbrock so it will be close to bottom of AC base as far as throttle cable when butterflies open. i trade off pod clearance with hood clearance. another option is a plastic pod that fits on top of TB and tubing routes to cold air with a filter there. that is a KN product for trucks BUT not for a modded vette for sure. also procharger offers a bonnet with the same idea.
Old Oct 18, 2004 | 02:27 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Those bonnets might actually sit taller. When I installed this intake I just screwed in the bolt as far as it would go and bought a 2 1/2" tall element, everything clears fine for me. Must be a different story with the Vette, in that you need an oval shaped one. Did you say how tall of an element you're using, I didn't catch that?
Old Oct 21, 2004 | 05:03 PM
Ronny's Avatar
flat base. tried a 3.00(edel) and a 2.75 inch(summit) oval. . unless i use the air cone(?) that comes with stock GM TB it hits the linkage. that lift the AC assembly 1 inch(?). with the cone in place i need a drop style and then the hood hits. i found a 2 inch flat element and a 2.5 inch drop base which i have not tried. think i am going ram air with $100 unit i saw at summit(truck TB) and then somehow link to c4 TPI ram air set up. combo so to speak.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
sailtexas186548
Feb 17, 2017 03:07 PM
PurelyPMD
May 5, 2016 04:57 PM
