Dyno tune time...finally!!!
Car: currently thirdgenless!!!
Just talked to the shop on the phone and they said torque was 275 ft/lbs. And max hp and torque was @ 4500rpm.
That seems like it might be a bit low.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Thats really funny that the HP and TQ peak are at the same rpm. I smell a fish, or is that static injectors?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
hmm, somethings not right.
The HP for 275lbs/ft at 4800 RPM, is much higher than any number you have receceived from them. Something is not adding at up all.
I will await a graphical result though.
has anyone else heard that that you are supposed to add 20% to the readings you get on a mustang dyno? i was told to do that from guys who have had time on a dynojet dyno. for some reason the mustang dyno read lower? anyone have first hand knowledge on this?
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
158 rwhp / 226 crank, that's a 30% driveline loss. That big of a differential does not make sense. If you haven't paid them yet, I'd wait until you are happy with their work and they've given you the data (graphs), not just a verbal over the phone.
You haven't said how the car drives yet. Does it feel any better than when you dropped it off?
Yes they have been paid.
And yes the car feels better than when I dropped it off. It runs a lot smoother.
I was also thinking that 30% loss in the drive train was pretty large. Expecially when I switched to an aluminum drive shaft. That is exactly what that mod was for.
At the moment I an not ruling out anything. So how would I check for a vacuum leak at the manifold?
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Your peak horsepower should be around 4500 RPMs and Torque should be a lot lower with your current setup. I agree that your loss through the drivetrain shouldn't be at 30% that seems way too high.
Your stock ignition could be holding you back not because you need after market stuff but because the stock stuff is old and worn.
whoa... yeah... peak tq shouldnt be up at 4500... not unless your redline is upwards of 6000... check for leaks, something is wrong... lol (as if we didnt already confirm that...) i dunno... maybe you can join bruce, nic and I on friday and maybe we can diagnose something....
Car: 84' Monte
Like it was mentioned earlier, mathematically there is no way your peak hp and peak tq could be at those numbers and be at the same rpm. So hopefully there was just a miscomunication.
I wouldn't blame the car yet, until you get some hard numbers you really don't know what's going on with the car.
I'm hoping to get a run in at the track on the 24th. Should have some times then.
In the mean time, if I download some data with Winaldl, what should I look for to tell me if there might be a problem somewhere?
Car: 91 Red Sled
I'd grab a multimeter and watch the o2 voltage under WOT. If it's dipping below 700mv at higher engine speeds (which I know it will with stock fuel pressure) then you've run out of fuel. Either turn it up in the chip and go static or increase the fuel pressure and start ALL over again with the idle and cruising fuel.
Car: 84' Monte
ummm.......yeah. Stock injectors at stock fuel pressure were borderline static from the factory, which means not much room for improved HP.
But seriously I wouldn't be chasing my tale around till I got some hard numbers from the dyno guys. Your basing all your troublshooting on false info. The numbers they gave you are not correct! They can't be, they had to have just guessed what you had made from memory or somthin. I would stop by the shop and see if they have the printer fixed and have them print out your dyno run. I would hope they would have saved all that stuff for future reference when tuning similar vehicles.
Car: 87 Firebird
Engine: 305 LG4
Originally posted by miacamaro305
yeah just look at the #'s in my sig those were stock rwhp #'s only mods were headers and a flowmaster and open element
Sig??????????????
I'll have another talk with them next week. I have to stop by there and pick up my adjustable pressure regulater. They did not give it back to me when I picked up the car. And I was in a hurry to get to work so I forgot to ask for it. But I called them and they still have it. I'll get some more facts when I stop by.
As far as the print out, they said they have to take the dyno down for 2 days to fix the print software. They said when they do the will be printing for a lot of customers.
Car: 1990 Camaro RS
Re: 305
Originally posted by davidb
i can't believe how many people waste money on 305's
You're lucky I'm not a mod, Please THINK before posting again. No one here cares about your useless comments, we would prefer not to see them. At such a point as you either a) have a question b) have something of use to contribute. Then we welcome you to post.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: 305
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
And you are lucky it was Dimented that got here first, I might not have been so nice cuz really, stuff like that is stupid. I'm gonna keep this thread open cuz Bill's car is an ongoing saga that I think everyone here in TBI land wants to know about, and if another comment like that surfaces, little red button time....
Bruce (90RS305)
Bruce (90RS305)
Car: 1990 Camaro RS
Bill is not exactly a young kid.
And this arguement has gone on over and over and over and over. There is never an arguement of a 350 vs 305, that would be stupid to think a 305 had the potential a 305 does. Do not take people on this board for idiots.
Considering the car in your profile, I assume you have an L98, which means you don't have TBI, and wondered over here to post something along the lines of 'My l33t L98 will smoxor the crap out of your crappy tree-o-fide'. You doubt you took the time to read this entire thread, or the tech in it.
NO one on this board would consider telling someone to spend $2000 updating a 305.
But since you want it, let start this arguemnt. How is modifing a 305 any diffrent than say, modifing TPI, which is an inherently flawed performance system right out of the box, you are spinning your wheels, and acting as your own worst enemy. You open it up for a bit of flow, you try to spin some RPMs, and the resenence tuning starts to work against you, and you wonder why your LTR setup won't make power at 6200 RPM, even after troughing $1200 at it. So you buy a mini-ram, HSR, or super-ram, now your at $2500 into your motor, but still have the stock heads, and are limited to about 350hp. shucks, another 1500, we are are now at $4k into this thing, you finaly have a bit of power, opps, you spun an old motor to high too late in its life, found the ridges in the cyl. walls, and now you need a rebuild, another $2k later, we are at $6k you got all your parts together, your new motor, then you figure out your tune sucks, so you spend 6 months learning to tune, or get a customer tune for another $1k. what are we at now $7k to get a 500hp motor? By that time, I could have put a Shafifroff in my car, had 700hp, and a warrenty.
BTW, wanna race my $700 bolt on 305 TBI, with you all conquiring 350. According to another post, you can't even keep your car running well, as it 'lags going into 2nd', It wouldn't even be a race. You are probably HIGH 14's at the strip, I can do that ALL day long, shifting a 3500 RPM without the nitrous. But what was I thinking throwing a whole $700 at a 305. Ohh, and that $700 include the extra 150 I have in a bottle out back. Yes, with that going, It should put me at least a couple of seconds ahead of you at the end of the 1/4mile.
I would guess if you have done some 'basic' TPI mods, you are approaching what I have spent on my car, and your still no where close.
End of this story, I am done with this.
Car: 1990 Camaro RS
Re: tbi
someone didn't get a valentine card yesterday
Thank you for proving my point, and not posting a technical response to my post.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well said Dewey.
Lets not run this into a 305 bashing extravaganza. There are reasons behind modding a 305 TBI but most people are blind to them.
He is probably not even aware that his beloved TPI system was originally developed for a 305. That's right, your running a 305 induction system!!!!
I should be making some major gains in tuning this weekend. Jon Prevost will be in town to help me with the tuning.
BronY
I did not get a print out. I had kinda forgot about it. I think I will give them a call and see if they ever worked out their printing issues.
davidb
If you ever saw my car in person, you would not consider any dollar I have ever put into it a waste of money.
TGO is a great community. Case in point, Jon traveling cross country to help out a brother thirdgenner. A New Jersey winter may have also had something to do with that. But that's ok.
I see you only have 30 posts, so your pretty new. Be a part of the crowd, it's pretty good. The technical info found in here is incredible. And the knowledge that others have about these cars is astounding.
Dewey,
But I'm a kid at heart.
BronY
davidb
Dewey,
Car: 1990 Camaro RS
Dewey,
Dewey,
Hopefully Jon will remeber his Burner :: blushes ::
Car: 1990 Camaro RS
Just checked $440 for me to fly out on friday.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Car: 1990 Camaro RS
Right on, I have managed to make on on 3GO.
I didn't know anyone over there still owned a thirdgen.
Shoot, I may have to try to dig up my old 3go password, and go post over there.
. Supreme Member
Engine: 305 TBI
Yeah I figured I'd check that forum out while this was down cause I was bored. Realized I had registered May of 2002 and had like 3 posts ha. Seems like there's really only a few guys with thirdgens.
Ahh....I love the TBI community, I think this is one of the only boards on TGO where everyone here is sypathetic toward everyone else cuz it's 95% LO3's
It'll be cool when Prevost makes it out here to AZ, you know I'll be making a cameo! I just wish you'd have stayed here another day Dewey!!
Bruce (90RS305)
It'll be cool when Prevost makes it out here to AZ, you know I'll be making a cameo! I just wish you'd have stayed here another day Dewey!!Bruce (90RS305)
Car: 1990 Camaro RS
I really enjoyed my time in AZ, even though it rained (but it was 70* and raining, big upgrade from the 35* and raining I left). I'll be back again. This time hopefully no parking tickets from the City of Phoenix
. lol, yeah, we are warm, were at sea level, we have two dragstrips reasonably close to Phx and ... there are a CRAPLOAD of 3rdgens out here.. lol... plus, who wouldnt want to come and see the Infamous Bruce and his Possessed LO3!!! lol j/k
The tuning went great. Jon determined that my injectors were maxed out @ 4000 rpm. We put on some 68# injectors and it really woke her up. I don't have final numbers yet. We are planning a dyno day in PHX around the end of March. I will have more then. I might get out to a track this week end. If I do I will post the numbers.
As far as the original print outs, I did get them and they said 157 rwhp. No to good. They did not do a good job with either the fuel tables or the spark tables. Jon took care of that.
His knowledge was unbelievable. I just blows me away that he wrote all of that software.
Car: 91 Red Sled
I didn't get to do everything I wanted too but we came a long way. It's a great base bin right now that still needs some idle work. There was an exhaust leak which also should be looked into. Get that fixed and see if it helps the warm engine idle, if not just try a few different burns where you lean out that area of the VE table, remember the adder table when you're adjusting the main table. If things improve you know you're going in the right direction
. Also might be too much timing at idle so take 4 degrees out from the main SA table and try that out but don't try both of those changes at the same time or might miss the tune
. Supreme Member
Car: 88 Camaro SC
Engine: SFI'd 350
Its cool to hear that you got it working well. The VE tables and the timing can be really tough to tune since theyre coupled. I dont think I was ever that good at picking out what needed to be changed at anything but WOT. Change the timing, and the VE changes. Conversly, needed timing changes can be masked by the VE changing and throwing the fuel off.
That sort of thing can make or break a setup.
Engine: 355 6"rod tbi - in the works
ok um...so JP... when is the next time you will be in....TEXAS! cool post, nice to the hp numbers climbing as the tune gets better and better. i keep going back and forth between tbi and mpfi... i can't frickin' decide, excuse my text.
Car: 91 Camaro RS
Engine: TBI
Wow thats awesome guy flys cross country to help out another, cant wait to see some new figures outta that thing.
I'll tell you why we spend money on tbi's same reason i have for modifying tbi's everyone says they're slow......you make it fast and people stand in awe
