How do you feel about E-Tec 200s ona 383 TBI?
Car: 94 ECSB Midnight Blue Z71
Engine: 350 TBI
Transmission: 4l60e
Anyone have experience with these? Thinking of running these on my still in planning 383 TBI. How will they do #'s wise? Also, can they be CA smog legal?
Car: 89 Camaro RS
Engine: 305 TBI
Well the 170's are supposed to outflow the stock vortecs by 30% maybe on the exhaust side. So the 200's should be well up there. For example, edelbrocks e-tec crate motor makes 435hp in a 350. I havent found out what their special cam is yet but I plan on it. Plus those are the 170's I think. I'm guessing their more of a high rpm power maker.
Car: My car uses gasoline
Engine: 383 cubic chaos
Transmission: a "man" trans
This shall be my first post, hey fellas. Umm, I have the ETEC200 heads on my 383 and I ran 12.43 @116 with only a dozen or so runs on my belt. This is in a #3500 race wieght camaro, manual transmission, bone stock wore out suspension, and 275/40/17 potenza tires with a 3.42 gear. A no nitrous no nonsense bad boy and I owe it too the Edelbrock ETEC200 heads. Well, that and my driving skills. I think if I did it again though Id get the 170s with fuel injection.
Car: White KSwisses
Engine: 5.3L Gen III
Anyways, with the E-tecs, because they dont have an EGR crossover, your gonna have to plumb the exaust from your headers to your intake manifold, which has to have EGR provisions, and in this case must also be a vortec manifold.
Heres are pics of the SDPC kit that allows you to do this
http://para.noid.org/~thresher/images/albums/021701/
(Pics courtesy of Kevin91Z, the 1st four show wut im talking about).
Engine: 350 TBI
Transmission: 4l60e
thanks for the pics, makes a little more sense now. Are the e-tecs worth the $$ + the vortec manifold for the power they make, or are there better heads out there in a similar price range, keeping in mind this is a truck engine im building so tq is key but hp is good too, and i need to be cali smog legal
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would not go with the 200's on a TBI vehicle. Your powerband and air flow criteria are better suited for the 170 heads.
Engine: 350 TBI
Transmission: 4l60e
already passed on the 200s figuring they were too big. If I do go with them I'll buy the 170s new. Is $1050 about the best I will find for them?
Engine: 350 TBI
Transmission: 4l60e
any suggestions? fairly new too all this. Biggest thing at the moment is being California SMOG legal, good price doesnt hurt either though
Car: 91 RS
Engine: 350 TBI
http://www.trickflow.com/product/che...r_23degree.asp
I have them on my 350 and they are awesome.
Engine: 350 TBI
Transmission: 4l60e
those look pretty nice, DD2K says 510 ft lbs and 375 hp w/ those on a 383 of my configuring, not to shabby. On the optimistic side, but still pretty nice numbers. Any other similar setups for less $$$, or is $1000-$1500 about what you will pay for nice alum heads?
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
That's about what you'll pay for good aftermarket aluminum heads. I would steer away from Vortec style heads if you have to keep it Cali legal, you'd have a hell of a time passing with that EGR situation.
Car: White KSwisses
The bigger problem here is having a 350 w/ a tbi. If you have a 350, yiu gotta go TPI or superram.
That being said, i would go with the trickflows rather than the vortecs.
Engine: 305 TBI
I just think that's a lot of hassle that many people don't want to undertake. I don't live in Cal, so I couldn't really say anything first hand. Does it pass the visual with that setup? That's pretty cool then that it leaves Vortecs as an option for ya.
Car: White KSwisses
But i agree with you in that its a bit of a hassle and i personally wouldnt choose that route. First off, your headers cant be ceramic coated before you weld on that bung. Second it limits your intake choices. Third, those trick flows are alumimum heads, and flow more than the vortecs.
Engine: 350 TBI
Transmission: 4l60e
so w/ the trick flows versus vortec or vortec style (IE E-Tec), what are my intake manifold options? Are there many, if any, performance TBI manifolds out there?
