Another of the most frequently asked questions Open element
Old Feb 17, 2005 | 12:33 AM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Ok I looked at that sticky up there and didnt say anything about my problem so here
I got an Edelbrock Open element courtesy of Autozone.........after I paid them
Well heres the deal If I leave the spacer on the stud comes up short if I take it off the base is too low(I think)
So guys what is it?
Can I get a longer stud or what?
Old Feb 17, 2005 | 12:49 AM
SchwarzCamaroRS's Avatar
i have the spacer on and the stud length is fine... hmmm.. i really dunno, pictues would be helpful. Many of us on here use that filter assembly courtesy of autozone and ours all work.. you might want to ask 90RS305, he is pretty darn good at that stuff, Shifty is pretty godly himself too... maybe the filter is installed incorrectly, or maybe if you bought a new one, you bought the 4" not the 3" other than that, i have no idea...
Old Feb 17, 2005 | 01:18 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
As long as it's a 3" tall filter you should be fine. Just unscrew the stud out of the base as far as you can go. When I had a drop base cleaner like that, I had to unscrew it but it still didn't fit so I took the stud out and bent it in a vice to make it straighter and longer: worked good.
Old Feb 17, 2005 | 03:02 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
How far off is it? if you can even just barely get a few threads to stick out of the hole then you're good. Once you start threading the wing nut on there it'll all squash down and be nice and snug. I've installed quite a few of these now, and have had to use a few nifty tricks...
Bruce (90RS305)
Old Feb 17, 2005 | 08:06 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree with the last two posts. Try backingout the stud a bit so that you can grab just a few threads. The open element will squish down a bit and become snug.
Old Feb 17, 2005 | 10:20 AM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Alright thanks guys
Ill try pulling the stud out some
as of now not a bit of the stud is showing so maybe that will help
Old Feb 17, 2005 | 10:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
is it a drop base housing, and what size element are you trying to use?
Old Feb 17, 2005 | 11:38 AM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
yeah its a drop base
and its a 3 inch tall element
I got it to work
so far now I have to do the rest of the hook up stuff
Old Feb 17, 2005 | 11:41 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You could probably make your own aircleaner stud with some rod and a few dies for cutting the threads. I think the standard aircleaner wing nuts have the same thread as the tbi so you could just bend a section of threaded rod to the right shape and use that instead.
Old Feb 17, 2005 | 01:42 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Its on!
I am the ultimate mechanic!!!!!...............only not
I got it on and it feels like it doing some good.
Heres another question while Im at it.
Should I spring for the K&N filter or not?
I would prefer answers from people actually running one on there car.
Thanks in advance
Old Feb 17, 2005 | 02:01 PM
BronYrAur's Avatar
Engine: 305 TBI
Don't bother with the K&N it's not worth it. Save the 40 bucks or so for something better. Plain old filter will work just fine and cost about 5 bucks.
Old Feb 17, 2005 | 02:54 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I agree. I have a K&N only for the "ooh and awe" factor. A standard paper one will suffice. I was more concerend with looks when I purchased mine.
Old Feb 17, 2005 | 04:15 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Is there really that little noticeable effect from it?
Or are they just for the guys trying to suck every last bit of power out of their motor?
Old Feb 17, 2005 | 04:24 PM
BronYrAur's Avatar
Engine: 305 TBI
It won't really give you any power. The good part of them is that they are re-useable. You can clean it and reuse it. You need to eliminate a ton of limiting factors in your engine and the air filter is not one of them.
Old Feb 17, 2005 | 04:35 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I'm not TBI, but I know what I do would carry over. I took out the stock studd and threw it away. I got a new stud from the local store. This one was just one really long threaded thing, with a wing nut. I trimmed it down, and now I can switch my stock air cleaner and my open element back and forth with no troubles at all.
Old Mar 6, 2005 | 12:40 AM
Gr89RS's Avatar
Car: '02 Z06
Why would you need to switch back and forth air cleaners???
Old Mar 6, 2005 | 09:45 AM
305q_ta86's Avatar
Transmission: 5 spd
I live in Canada. THERMAC is my friend.
Frozer!!!
Jan 19, 2024 04:55 PM
89gtaforsale
Aug 24, 2015 09:32 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
