how do i set the timing on a 91 tbi 305
Old Mar 1, 2005 | 10:10 PM
guest2's Avatar
well we finaly got the camaro painted (repainted factory charcole grey) and its going to be leaving us soon but we need to time it first. to restate i dont own this car so i know nothing how it works. is there a plug or something that needs to be unpluged to make the computer stop messing with it so it can be timed? and what should the base timing on this 305 tbi be? (the engine tag is missing)
Old Mar 1, 2005 | 10:36 PM
guest2's Avatar
i asked my friend and he told me "unplug the brown/black wire that is hanging off to the passenger side fender well area. At idle the stock 350 is 8 degrees and the 305 is 6 degrees "
is this correct? does anybody have a pic or better discription of this wire?
Old Mar 1, 2005 | 11:29 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
305 tbi is at 0. Once timing is set, disconnect battery for a few seconds to remove engine code from computer.
Old Mar 2, 2005 | 01:10 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
I like 4*BTDC with 89octane.
Old Mar 2, 2005 | 03:03 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
i believe its the second post that AJ gives about the perfect outline to adjusting the timming on our engines. Check it out herehere
-chillen
Old Mar 2, 2005 | 08:09 PM
guest2's Avatar
thanks for the help guys.
i tryed to set the timing to 0*; but it wouldnt run anything less than 8*btdc
Old Mar 2, 2005 | 09:52 PM
86z/92rs's Avatar
Id this the orignal engine, how many miles on the engine? Have you checked your harmonic balancer to make sure the elasto...(the rubber thing on the balancer) is cracked to the point that the outer ring may have moved.
Old Mar 3, 2005 | 12:19 AM
guest2's Avatar
the engine is origenal and only has about 60k on it it was driven only to car events (their daily driver is a pos honda; and i wouldnt drive that to a car show)
MustangBeater20
Oct 29, 2022 09:20 PM
mhatfield 14
Oct 24, 2015 07:48 AM
justin57
Aug 20, 2015 07:05 PM
MENINBLK
Aug 5, 2015 11:58 PM
