What the heck is this?
Old Apr 5, 2005 | 03:35 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
The previous owner of my '92 RS screwed up the wiring in this car so bad I don't know what is what most of the time. Can anyone tell me from the pictures below, what this wire is to? It is grounded to the bolt in the strut tower. I have circled it with yellow to follow the wire.
Old Apr 5, 2005 | 03:36 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Here's another angle:
MOD EDIT I attached these as pictures instead for your viewing pleasure...
Old Apr 5, 2005 | 10:31 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The wire color looks really familiar: green with white stripe. Ill have to check a manual to see what it really is, unless someone already knows.
Old Apr 5, 2005 | 10:41 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
It looks to be grounded to the strut tower but where does the other end lead to?
Old Apr 6, 2005 | 03:45 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
does your fan run at all times?
Old Apr 6, 2005 | 07:27 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Yes.
Yes, my fan runs with the ignition in the "on" position most of the time. It has been turning off randomly in traffic lately, but then I turn on the AC and it comes back on. The wire is green and white from what I can see. I cannot lift the car due to lack of jack stands at the moment so I can't see where it disaapears to. Any help is greatly appreciated!
Old Apr 6, 2005 | 09:36 AM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
I'm showing Dark green and white as ground going from the Coolant fan relay to Fan A/C pressure switch, A/C control Head and the Coolent fan switch.
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
It looks to me like the previous owner disconnected and cut the connector off for the coolant fan switch (located in in the passenger side cylinder head in between the #6 and #8 spark plugs) or AC pressure switch and just grounded it, which would explain why the fan is on at all times. The wire for it is green/white.
Old Apr 6, 2005 | 10:07 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Benm, man I think you are probably right, and I hope that is all it is! As soon as my RS comes back from getting a hatch leak fixed I'll tend to that, but I hope you are right, that would make a lot of sense and save me time and money if that is all it is.
Old Apr 6, 2005 | 07:41 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
yeah that is what it is... i have mine like that but the ground is hooked up to a fan switch.
Old Apr 7, 2005 | 01:12 PM
SchwarzCamaroRS's Avatar
i did mine that way as well, but mine is grounded near the relay, not on the pass/side of the car.. seemed easier to do it that way...
Loudnproud86
Jul 14, 2016 12:59 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
DonW
Carburetors
Sep 23, 2015 08:04 PM
aharvel50
Sep 21, 2015 07:31 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
