Egr Again!!
Old May 17, 2005 | 02:17 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Egr Again!!
Hey guys i just replaced my EGR and EGR silnoid. I was driving on the freeway and the SES light came on!! WTF!!! So i pulled the codes and I get a code 32 I got the EGR from the dealership and the silnoid from autozone.. What could be causing the to happen? Do you think my Passages are cloged up? I just passed smog with flying colors. Help!!
Old May 17, 2005 | 03:25 PM
vjo90RS8's Avatar
Car: 2002 Z28
do you have a negative or positive backpressure valve on there right now, and what was your original one (if you still have it). You can check by looking at the top of the valve, there should be an N or P on there.
Old May 17, 2005 | 05:29 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
im not sure i just went by what the dealer gave me. I forgot what is was. But this all started after i put my open element on. Ill go check and post what it is.
Old May 17, 2005 | 08:32 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I think its a N cause there is a bunch of numbers and at the end there is an N. I didnt see any P so.... I pushed the diaphram in and it held vaccuume with my figer cover the vacuume hole..any ideas?
Old May 17, 2005 | 09:51 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
I assume you tested the valve with the car running by pressing the diaphragm and hearing the car bog down. the passages aren't blocked. your dealer more than likely gave you the correct parts. Since you wouldn't be able to depress the valve in a positive EGR (i believe). I too have this recurring EGR problem. Most seem to have agreed it's prnobably a vacuum leak (not in the lines but on the block somewhere), confusing the sensors that check to see the pressure change of egr being open.
Old May 17, 2005 | 10:05 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Well i checked the EGR with the car on and it didnt really do much. No changed in the motor really. Does this mean that the passages are blocked?
Old May 17, 2005 | 10:18 PM
safemode's Avatar
Car: camaro rs
well yea, if you pressed in the valve with the car running, you should have definitely heard a change in engine noise. If you did not, spray some 2+2 in the passages when the engine cools down. really get that crap cleaned ...wait until it dries and fire it up again. if that dont do the trick, you may need to run a pipe cleaner through the manifold (after taking it off) but that's just me guessing. I've never had to clean the egr passages before. Mine are clean, I still get the light, so that's never been my problem.
Old May 17, 2005 | 10:56 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Probaly the only way is to disable it when i do my programming huh? I thought i had it fixed cause before i got the car smog the light didnt come on anymore till after. thanks for the help safemode.
Old May 18, 2005 | 02:49 PM
safemode's Avatar
Car: camaro rs
you can block it off ...though it appears that is the problem since depressing it did nothing to the engine. Disabling the programming is only really good if you have a big cam that does EGR on it's own, otherwise you should probably clean the passages so it allows exhaust flow through the EGR.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
