O2 problem error code 13-sensor is working fine
Old Jun 9, 2005 | 04:59 PM
Siwir's Avatar
Car: Camaro RS 1989
Engine: 383 Holley 950 TBI
Transmission: TK0-600
Axle/Gears: BW
Hi,
From last time I have problem related to 13 error code, which appears during few minutes of uniform driving. Of course the mileage is bed, and some vapors odor I feel. When I accelerate and decelerate it seems to work fine. (the same situation is when I go over 2500 RPM during few minutes without driving).
I've checked at least 2 O2 sensors, and it wouldn't help. WINALDL shows signal around 0,5 V from the sensor. I have no experience what additional info from the log can be helpful to diagnose the problem. BTW Does anybody can look my logs ?
Do you have any idea what should be the next step to check ? or where the problem is located ?. I'm planning to swap new engine and in order to avoid problems I want resolve all issue before. (Just yesterday received some new 383 parts from US).
Thanks in advance for your help.
The car is 305 '89 TBI Camaro
Old Jun 9, 2005 | 06:14 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Is the voltage a constant .450 volts? IIRC, if the O2 fails to swing back and forth from around .3 volts to around .8 or so then the ecm will set an error after a period of time.
Old Jun 10, 2005 | 11:26 AM
Siwir's Avatar
Car: Camaro RS 1989
Axle/Gears: BW
Yes I just checked and the signal from O2 sensor is varying from 0,42 to 0,48 V. It seem that when coolant is above 80 C and during few sec signal stays constant then 13 error code appears.
What is the reason ???. I've checked at least 3 O2 sensor - result is the same ? HELP
Old Jun 10, 2005 | 12:23 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Sounds like there is the possibility of an open circuit somewhere thats interrupting the O2 signal. Check the wiring near the O2 as well as the connector for damage.
Old Jun 10, 2005 | 02:00 PM
Siwir's Avatar
Car: Camaro RS 1989
Axle/Gears: BW
So as you recommended I have disconected O2 sensor and the WINALDL shows exactly the same results ~0,45 without O2. I will double check connector, but is there any possibility the the ECM is broken or it's related only to the wireing ?
Old Jun 10, 2005 | 02:08 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Anything is possible. More likely a wiring problem then the ecm, though. Also, are your headers long tubes, or shorties? The O2 sensor must get up to around 320 degrees C or so to start working. If you have long tubes, the O2 may just not be getting warm enough.
Old Jun 10, 2005 | 07:09 PM
Siwir's Avatar
Car: Camaro RS 1989
Axle/Gears: BW
Problem resolved: Connector was OK but the cable from O2 to ECM is broken somewhere. I connect new cable from O2 to D7 ECM pin and the code is gone. O2 voltage is varying now from ~0,01 to ~0,9 V.
Thank you for you help.
1992rs/ss
Jan 31, 2025 05:10 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
