does anyone have the this thread info?
Old Jul 11, 2005 | 10:24 PM
markuzzz13's Avatar
Car: rally sport camaro
i need the information about the lt1 cam swap fuel system what people had set up if you could post a link i would appreicate it alot thanks sry for the post
im just woundering about the electrical fuel pump and what you have to set up and what one to use without having the engine run too rich or lean
Old Jul 12, 2005 | 08:01 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The fuel pump supplies a fixed amount of fuiel at all times. When poeple do the LT1 cam swap they somtimes find that the stock pump cannot supply enough guel for the WOT fuel demands of the motor. They therefore upgrade fuel pumps. The way that they can tell if they are rich or lean is through chip work. The ECM and the paraemters in teh chip are what determin how thse engines use the fuel. The reason why your car will run rich/lean with an LT1 cam swap is because you are using the stock parameters in teh chip. Those parameters are set up to run a 170hp engine at a certian VE with certian fuel and spark valuse. Changing the cam requires changes to the chip in order to run the way it should with a new cam. You can barely bandaid the problem by manually adjusting the fuel pressure at the regulator but the only way to have the proper fueling for your motor is through chip work. In the end you will use the ECM to tell you if you need more/less fuel with larger injectors/fuel pump.
Old Jul 12, 2005 | 12:44 PM
markuzzz13's Avatar
thanks for the informationa i'll keep this in mind once i begin the cam swap but with the ECM i could burn my own chip correct ?
or will i have to have someone burn a custom chip for me
ive also heard that the lt1 cam is missing the fuel pump lobe on the cam thats the main reason im asking this question
Old Jul 12, 2005 | 01:44 PM
NEEDforSPEED's Avatar
You can burn your own chip if you have a burnner, editer etc, it takes time but its well worth it, you can get someone to burn a custom chip for you but its not going to be as good since no ones there data loging or seeing what your car needs, i like to call them "hit or miss chips" there is no fuel pump lobe
Old Jul 12, 2005 | 02:45 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Our cars have electric fuel pumps, so there is no need for a fuel pump lobe on the cam.
Old Jul 12, 2005 | 05:06 PM
SchwarzCamaroRS's Avatar
well, newer fuel injected versions of our cars dont have fuel pump lobes... some older ones do. but the LT1 cam wont, all LT1's used electric pumps
Old Jul 12, 2005 | 05:07 PM
markuzzz13's Avatar
newer versions being ?
Old Jul 12, 2005 | 05:31 PM
anything with TBI or TPI... all the TBI/TPI cars have electric in-tank pumps
Old Jul 12, 2005 | 05:43 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
True but they (TBI) also had a fuel pump lobe. If you converted to a carb set-up you could use a mechanical fuel pump.
Old Jul 12, 2005 | 06:37 PM
hmmm, i didnt know that, thanks shifty... lern sumfin new every day...
Old Jul 12, 2005 | 07:05 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I belive there were a few TBI grinds that did not have a fuel pump lobe. I believe someone had a '92 grind that had no lobe. My '90 had a lobe and it can be seen in the LT1 cam digest.
Old Jul 12, 2005 | 09:31 PM
markuzzz13's Avatar
wow thats weird how GM put that pointless lobe on there if its already has a electric fuel pump thanks for the help and info
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Linson
Sep 21, 2015 01:08 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Thornburg
Sep 12, 2015 10:11 AM
JamesC
Northern Great Plains and Rocky Mountain
Sep 10, 2015 07:41 AM
