Will I get any Gains from K&N Xtream Air cleaner lid??
Old Jul 13, 2005 | 05:29 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Ok, i recently noticed that K&N came out with an xtream air cleaner lid for all factory GM vehicles from 1968 to 1995 (summit # KNN-66-1201). I'am thinking about putting it on but want to know if you guys think it will even benefit my car..
Before you say just get an open element, i want to let you know that i ordered all the parts to get an open element alittle while back but i didnt like how you had to drill a hole for the IAT sensor, how you had to relocate the breather and all of that, and just how it looked out of place in my engine bay.
So i figure, the stock intake is already sucking as much air as it can possibly hold through that tiny *** tube, and that even with my air filter just being 'open' at the top should allow a decent amount more air through (be it not as much as an open element though).
What do you guys think? (I wouldn't expect gains as much as from a regular open element, but i am wondering if i would get any gains at all?)
Old Jul 13, 2005 | 06:20 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
yea, i think you will see some gains
Old Jul 13, 2005 | 06:26 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
Drill a hole for the IAT sensor I zip tied mine to firewall away from as much heat as possible, since i have source for fresh incoming air its going to mounted somewhere else. As for that breather tube a chrome can be purchased at advance autoparts for a few bux.
there isnt much clearance between the hood and the top of the cleaner to allow you to see much of a gain, but anything is better then than that stock lid, Money wise-- for as much as you'd pay for the extreme lid an OE can purchased. and it wont look out of place, if done rite. There are pictures of TGO members engine bays somewhere on this site button will help you find them.
Old Jul 13, 2005 | 09:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you don't want to drill a new hole for your IAT than I wouldn't bother ever modding your car. The extreme lid will do nothing for your car unless you rig up a true cowl induction. The stock hood will slam right up against it blocking any air that could possibly get to it. I have this lid but only for asthetic reasons. It looks better when my hood is up at car shows but I know it does nothing for performance with my stock hood.
Old Jul 14, 2005 | 03:55 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Shifty beat me to it. The only thing that lid is good for it a scoop/cowl hood application. If you still have the liner under your hood and you already have an open element on your car, you will notice the dent in it from the lid of the open element. If you are still running the stock intake, it's only about a 1/2" shorter. Air would have to climb up, change direction, go down, change direction again, go in, change direction yet again, then finally enter you engine. Reminds me of that thread from WAY back in the day when someone was talking about drilling holes in the top of the cleaner lid
Old Jul 14, 2005 | 01:10 PM
a mack6's Avatar
Alrite, thats all i needed to know...
After looking for an open element that would look good in my stock engine bay, i found this one on summit (# PRO-141-752)...its black and says chevrolet around the rim of the lid and the wingnut is a chevy logo. Its $60 and it's gonna be about another $50 for a K&N filter to fit it, but ill get it eventually, probably in the fall/winter sometime. When i do get it, i'll make sure i can find the proper tools to drill a nice hole out for the IAT and do something about the breather.
Thanks for the heads up.
Old Jul 14, 2005 | 05:57 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here is what my 14x3 K&N w/ extreme lid assembly looks like.
Attached Thumbnails Will I get any Gains from K&N Xtream Air cleaner lid??-bestshot.jpg
Old Jul 14, 2005 | 06:24 PM
a mack6's Avatar
yea i must admit that does look good--one of the best looking open elements ive seen, but i think that when i do buy the open element, im gonna get that one from summit thats black and says chevrolet on it (summit # PRO-141-752) . I think that would look pretty 'stock' in my engine bay. What do you guys think?
I probably wont be getting it until atleast the fall because i need an outdoor car cover (im gettin a nice one from CCC) and buildup some savings incase anything on my car goes, first.
Old Jul 14, 2005 | 07:43 PM
Z28GEN3's Avatar
Engine: 305TBI
I vaguely remember that.
Just a thought...
I know summit sells reuseable filters seperately that are a little bit less expensive then the K&N's. (SUM-239142 thru SUM -239146) from 25.95 to 39.95
Old Jul 14, 2005 | 08:25 PM
a mack6's Avatar
When it comes to my car, i don't 'skimp' on anything. If i'm going to put an air filter in, it's going to be the best air filter you can buy...thats just me though...I'm not going to do much to my car, so i figure that what little i'm going to do to it, should be of the highest possible quality.
Old Jul 14, 2005 | 08:46 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
Screw the Lid, im sporting the Edlebrock!
Old Jul 16, 2005 | 04:52 AM
SchwarzCamaroRS's Avatar
Ditto! 30 bucks at autozone!!!
Old Jul 17, 2005 | 12:47 PM
a mack6's Avatar
What the hell is this??
I was just looking through the air cleaners on jegs, to see if they have any different air cleaners than summit, and i found this... i dont know what the hell it is, but i've never seen it before and wondering if any of you could explain it to me. Sounds like BS....
http://www.jegs.com/cgi-bin/ncommerc...84&prmenbr=361
Old Jul 17, 2005 | 01:31 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Shifty,
How important is it to drill the hole for the IAT? I also have mine ziptied to the firewall. I have always wondered about that.
Bill
Old Jul 17, 2005 | 02:23 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
you'll gain about .0001 hp lol!
Old Jul 17, 2005 | 03:32 PM
Nice dude i would be smoking the ricers then!! Yeah!!
Old Jul 17, 2005 | 05:41 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
did anyone mention that the lid wouldn't even fit on a stock air cleaner assymbly? their not even the same size.
Old Jul 17, 2005 | 06:52 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Ding ding ding.
Ding ding ding.
Old Jul 17, 2005 | 07:01 PM
JesasaurusRex's Avatar
heres mine
Old Jul 17, 2005 | 07:08 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
^thats a purdy motor
Old Jul 17, 2005 | 08:17 PM
a mack6's Avatar
OK here is where reading comprehension comes in handy. If you would have thoroughly read the first post it says that K&N came out with a new xtreme flo lid that fits ALL STOCK GM VEHICLES FROM 1968 to 1995!!!. Check the part # on summit if you don't believe me.
And no, after shifty and 90rs305's advice i am not going to be getting the lid...but i had to clear that up about how it would fit on a stock TBI air cleaner.
Old Jul 17, 2005 | 08:33 PM
y thank you
Old Jul 17, 2005 | 10:13 PM
Just buy an aluminum bowl from the dollar store and cut it out.
Old Jul 19, 2005 | 11:24 PM
92HeritageT~Top's Avatar
Car: 92 Heritage T-Top
Transmission: 5-Speed
Just throwing this one out there...but what about a dual-snorkel filter housing? From a 350 HO. I have one on mine and it breathes 10 times better than the stock housing and I still get nothing but cold air...
Hey DevilsAddvocate, how much difference can you tell with the X-Air lid on that set-up? I have always wondered about the gains when used right...
Don't mean to jack the thread, but has anybody ever heard of those "Tornado" thingy's? They're supposed to give the incoming charge a decent swirl to aid atomization...but has anybody ever used one? If so did it actually work? Not getting one...just wondering...
Old Jul 20, 2005 | 10:10 AM
a mack6's Avatar
Yea man i wish i could find a dual snorkel...but it would have to be a factory GM one because i want my engine bay to appear 100% stock. I didnt know that 350 cars had dual snorkels....which cars had dual snorkels that would fit on ours besides the l69 HO 305????
Old Jul 20, 2005 | 10:17 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Never used one, but I have never seen a positive review or seen a gain of any kind from one. It's total BS, to put it nicely.
Old Jul 20, 2005 | 12:49 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I was going to buy that chevrolet one that you mentioned, but I found one that I like more... I just want that chevy wing nut now... Summit # PRO-141-790
Old Jul 20, 2005 | 12:51 PM
jimp2001's Avatar
Engine: LO3 305 TBI
Theres a dual snorkel for sale on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Jul 20, 2005 | 01:09 PM
a mack6's Avatar
Damn i wish i had $75 to spare!!!!
EDIT: And that PRO-141-790 chevy air cleaner looks damn good, but its $140!!! For the price, i'll get the other one which is $60...or a dual snorkel if i can find one, and have the money for it...
Old Jul 20, 2005 | 01:17 PM
jimp2001's Avatar
Engine: LO3 305 TBI
yeah but it's only a few bucks more than the complete 14x3 K&N X-Stream Setup... I'm going to buy it.. I'll post pics as soon as its installed
Old Jul 20, 2005 | 01:36 PM
a mack6's Avatar
Please do post the pics when its installed... thats very similar looking to the proform black chevy air cleaner i want to get, and i wanna see how damn good its gona look!!!!!!
Old Aug 22, 2005 | 10:09 AM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
i run the edelbrock like TWICEtheRICE. mine had an adaptor for the breather on it. i cut it out and stuck a hose up 2 it and it looks good! i can post a pic if u like. i drilled the iac in too. i used the old spacer though because i was afraid of hitting the coil wires. all i did was unscrew the threaded piece a little that keeps the lid on so it would clear the top so i can get the wing nut on. i plan on changing the filter itself to a k&n when this one dies out.
Old Aug 26, 2005 | 04:39 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i have the same setup as shifty, and while it does look purty i agree that i get nothing more from it. i do plan on getting a small cowl hood one of these days so it might be put to use.
anyone ever made a custom air box for their cowl hood so that you only get the outside air into the filter assembly? the only thing i would be concerned about would be heavy rain water but i'm sure a drain hole could be incorporated easily.
Old Aug 26, 2005 | 06:55 PM
rs coastie's Avatar
Car: 91 camaro rs
Engine: tbi 305
Transmission: 5 speed
how much do the xtreme air lids cost, i already have an open element but but i just got a jongbloed 3inch cowl hood and i would imagine that xtreme ail lid would work quite nice
Old Aug 26, 2005 | 07:06 PM
jimp2001's Avatar
Engine: LO3 305 TBI
hey can you send me some pics of that hood mounted to the car? the pics on G&T's site sucks, and I want to buy the hood, just want to get some more pics before i invest $$$ in it.
my email is jimp2001@aol.com
Old Aug 26, 2005 | 08:39 PM
Benm109's Avatar
Engine: 305 TBI
They usually cost around $55-$70, just depending on who you buy from and what style you want:
http://store.summitracing.com/egnsea...171+4294851316
http://www.jegs.com/cgi-bin/ncommerc...18&prmenbr=361
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
