Leaky injectors
Old Aug 7, 2005 | 08:56 PM
Phantom Champ's Avatar
Car: 91 Formula
Leaky injectors
At over 200K, I don't know if they are the original injectors or not, but how long do they typically last?
I'm thinking of just buying the new o-rings kit becuase the injectors themselves are about $120 each.
The injectors only dribble when the engine is running, but not when just the key is on.
I replced the fuel meter cover about year ago.
I'm pretty sure I just need new o-rings, but to TBI injectors really last 200K with no problems?
Old Aug 7, 2005 | 10:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
How does the car run? It is very normal to see a conical shape to the TBI injector spray with the occasional drip.
Old Aug 7, 2005 | 10:02 PM
Car: 91 Formula
It runs fine, but a little rich. No trouble codes and it backfired once last week, which is why I checked the injectors.
Old Aug 7, 2005 | 10:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
These injectors are pretty tough. If they give a good spray pattern when you snap the throttle open then dont worry too much about it.
Old Aug 7, 2005 | 10:30 PM
Car: 91 Formula
Yeah, the spray pattern is looks good. I'll just replce the o-rings.
Old Aug 8, 2005 | 03:44 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Yeah, I'd just get the TBI rebuild kit with the 2 sets of o-rings and the filters and it should seal up good. When I tried to use old o-rings, they dripped at idle pretty bad. Get new o-rings and grease them up before installing them and you should be good to go.
Old Aug 8, 2005 | 06:52 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Definitely do the rebuild kit they are like 30 bucks or something. Take that bad boy apart and clean it all up. Helps a little.
Old Aug 9, 2005 | 09:42 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
mine was doing pretty much the same and it was the o rings...while youre at it either replace or clean the filters at the bottom of the injectors .that'll help also...whan you take the inj. out pull up and give a slight twist to break loose they will be tough but they'll come out...and like stated before use a little lube(motor oil)to grease up the o rings before installing them...I promise you will tell a differance...(while you have the top off turn your fuel pressure up about 2 full turns and advance your timing a little...done it, it helped mine out tremendously)
Old Aug 10, 2005 | 05:07 PM
If you get a good rebuild kit it will come with all that crap even the filters for the injectors.
Old Aug 10, 2005 | 07:08 PM
Car: 91 Formula
Nobody around here has the rebuild kit or the o-rings in stock. I may ahve to order it online. Where did you guys get yours?
Old Aug 10, 2005 | 07:14 PM
Car: 91 Formula
double post
Old Aug 10, 2005 | 07:16 PM
dwillis's Avatar
Axle/Gears: 3:08
part #
go to autozone or go to autozone.com and choose search for a part number...you may have to put in your vehicle type but search for part #96-3013A.this is the kit i used to change my o rings and several other gaskets are included too...and its only $5.99...theres another one for about $40 that has alot more parts in it but this one was plenty to seal and clean up my tbi.I think you eill be satisfied also...
Old Aug 10, 2005 | 07:17 PM
dwillis's Avatar
Axle/Gears: 3:08
sorry.i almost forgot its a gp sorenson name brand
Old Aug 10, 2005 | 07:23 PM
Car: 91 Formula
I went to Autozone a few minutes ago, having the part # is a big help, thanks.
After I told him what kind of car I have, the genius there told me the biggest engine that came in my Firebird was a 3.1 V6. His computer screen said "Sunbird" on it. I just left, I couldn't handle it.
I'll try Kragen or somewhere else tomorrow.
Old Aug 10, 2005 | 07:30 PM
dwillis's Avatar
Axle/Gears: 3:08
yeah i have one person i talk to at our local one.if hes not there i just leave...most of them dont know a whole lot about cars and think they know it all...and heaven forbid you question them...jus go back and insist you want you want that part#...and pardon their ignorance...its not their fault
Old Aug 10, 2005 | 07:46 PM
Car: 91 Formula
http://www.partsamerica.com/ProductD...number=963013A
Looks like Kragen will have it, but in that picture, it looks like there is only 1 o-ring.
Old Aug 10, 2005 | 07:56 PM
dwillis's Avatar
Axle/Gears: 3:08
man mine had a whole lot more parts than that..try autozone again with that exact part#...i've still got the original box and extra parts after rebuilding it...i'll try to post a pic in a minute
Old Aug 10, 2005 | 08:00 PM
Car: 91 Formula
from Autozone.com
Search Results
Search Term: 96-3013A
Searched: Entire Catalog
Sorry, there are no exact matches for your search term. Some possible matches are listed below.
ACCESSORIES
1 Ton W-300 Series 1958-1967 6 Bolts/16 Splines
12 Circuit Chevy II/Nova Harness (1966-1967)
12 Circuit Chevy/GMC Pickup Harness (1963-1966)
14 Circuit Bronco Harness (1966-1977)
150hp Upgrade for Performer EFI Dry Nitrous System for 1986-95 Mustang 5.0L & 1996-98 4.6L (80 HP)
18 Circuit Camaro/Firebird Harness (1967 & 1968)
18 Circuit GM 2X4/4X4 Truck Wiring System (1967-1972)
18 Circuit GM Muscle Car Harness (1969-1974)
2 & 4WD 92-96 Ford Ford Bronco
2" Fuel Level, 0 E/30F,(GM) Pre 1965
2" Fuel Level, 0 E/30F,(GM) Pre 1965, Phantom
2" Fuel Level, 0 E/30F,Pre 1965 (GM)
Old Aug 10, 2005 | 08:11 PM
dwillis's Avatar
Axle/Gears: 3:08
give me about 5 minutes im going to try and help you out...be right back.
Old Aug 10, 2005 | 08:15 PM
Car: 91 Formula
No rush. Thanks, buddy. I'm from TN originally.
Old Aug 10, 2005 | 08:35 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Don't forget to put ATF, yes Auto Tranny Fluid on the O-rings when you install them. The Rebuild Kit should tell you to do this, but it is crucial for proper sealing and longevity of the O-rings.
Old Aug 10, 2005 | 08:38 PM
dwillis's Avatar
Axle/Gears: 3:08
go to autozone and click on shopping...then click on part number search...then enter the part number...i couldn't figure out how to post the location here but do that and it'll be there.....heres a small pic of the extras i had left over after replacing the o rings and other parts and gaskets too
Old Aug 10, 2005 | 08:41 PM
Car: 91 Formula
I've read that about the ATF, but some people say they just use motor oil.
Old Aug 10, 2005 | 08:45 PM
Car: 91 Formula
OK, Part # search worked.
only $6.99
Old Aug 10, 2005 | 08:49 PM
dwillis's Avatar
Axle/Gears: 3:08
told ya ...and you get plenty of stuff to seal it back up really good...use atf or oil..your choice. i used oil, because its what i had handy ...really hope this helped you man keep me posted....which part of TN you from?
Old Aug 10, 2005 | 08:54 PM
Car: 91 Formula
Nashville.
Thanks for your help!
Old Aug 10, 2005 | 09:00 PM
dwillis's Avatar
Axle/Gears: 3:08
no prob man
Old Aug 6, 2006 | 07:59 PM
Car: 91 Formula
I'd forgotten about this thread. I bought the rebuild kit a year ago and haven't done a thing to my car since.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
