smoke at start up...common 305 problem?
Old Aug 11, 2005 | 07:58 AM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
my 305 in my 89 formula smokes when i start it. its blue too so..u guys have any experence with this, its prolly the valve seals right? how hard is this to do? thanx for your input
Old Aug 11, 2005 | 09:54 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You have the age old problem of dried out valve seals. A few searches will tell you which ones people prefer and I have some steps to installing them in the LT1 cam digest above.
Old Aug 11, 2005 | 10:38 AM
Car: 1985 iroc-z
cool, thanx man. sorry posting something thats probably overkill
Old Aug 11, 2005 | 02:45 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Mine have been smoking at start up for many years. Over 100K.
Old Aug 11, 2005 | 03:18 PM
Car: 1985 iroc-z
at work (i work at a pontiac dealership) i found a bullitin and gotta part number for the umbrella seals that replace the old o-ring ones. all i need is the spring compressor and the fitting to get air in the cyl, and ill be good.
Old Aug 11, 2005 | 03:38 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I wouldn't bother with compressed air. It is very hard to make work with the motor in the car. Your air line line and chamber adapter will be in the way of everything. You are much better off using thick nylon rope to shove into the chamber. This way you don't have to do one seal and then tear down and re-set up for the next one.
Old Aug 11, 2005 | 04:12 PM
Car: 1985 iroc-z
hmm....yeah sounds good. plus ive got headers there too not fun
Old Aug 11, 2005 | 05:20 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
I have to do two cars with of seals.... can you explain your nylon rope method in some detail, and how to do it in the most time efficent manner? Thanks....
Old Aug 11, 2005 | 06:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is actually pretty easy and I find it much faster than using the air method. You feed the nylon rope into the spark plug hole after you pull the valve covers remove the rocker nuts and take off the rockers. All of the valves will be closed now and seated up in the heads. Then just start feeding in the nylon rope. You can get enough into the chamber where it will act as a support for the valves when you take the springs off. You also won't have to worry about an air leak or something going wrong with your air hose causing the valve to drop into the head. The air adapter will also ram right into the exhaust manifold with the air line connected. There is just not enough room for every cylinder. The air method also doesn't guarantee that the valve will stay up in the head. I have always had problems with exhaust valves. Even with 100+psi of air pressure, I would still push the valve down with the spring compressor. Not only was this very loud (air going in and out of every path of your motor ) but it was incredibly annoying. A few taps with a rubber mallet didn't always un-bind things either. This frustration is with the motor out of the car as well to put things into perspective. The rope will help push up against the valve and ensure that it stays in place enough for you to get the valve locks out. A tiny magnet really helps here. I use a pen magnet that you can get in the checkout line of AutoZone. Even if you leave a few tiny threads of nylon behind be assured that they will vaporize once you fire her back up. Just make sure you use the water proof plastic feeling rope. It is basically the rope they use for marine applications. ¼” or so will suffice.
Old Aug 11, 2005 | 08:45 PM
GOY's Avatar
GOY
I like that.... seems like it would work great at keeping all 16 valves up at once and ready to go.
How long does it normally take you to do a seal job? I can't imagine more than about 2-3 hours, valve cover off to on.
Old Aug 11, 2005 | 08:50 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I like that.... seems like it would work great at keeping all 16 valve up and ready to go.
I can do a valve seal job in about three hours or so. You will spend more time crawling around the engine bay than you will with the actual work . If you thought installing spark plugs was tricky than you will love feeding string into the chambers . This method is far more forgiving in the end though. You can have the valve covers and rockers off in a few minutes. It is the organization of valvetrain parts and planning for the next steps (nylon string placement) that take the most time.
Old Aug 11, 2005 | 09:12 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
anyone have a part # for the valve seals?
Old Aug 11, 2005 | 09:58 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You can go more than one way with valve seals. I would spend some time using the search function to read up on others experiences with this matter. I run intake seals on both valves.
Old Aug 11, 2005 | 10:27 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Yeah mine were toast also until the head gasket blew so now the engine is no longer running no need for valve seals just upgrade to a 350 lol!!
Old Aug 12, 2005 | 07:34 AM
Car: 1985 iroc-z
part number for the new unbrella ones is 12511890.
Old Aug 12, 2005 | 02:23 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
I have the same thing happen. But it's only if I let the car sit for a day or more. If I go to work and leave for lunch there is no smoke.
Old Aug 12, 2005 | 04:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You have bad valve seals as well. When the motor sits oil drains away from the seals and they harden up. When you start the motor oil slips right past them until the heat of the engine swells them up a bit. Even at that you are still burning trace amounts of oil that you can't see out your tail pipe.
jhawkeye
May 25, 2022 06:33 PM
bryan623
Mar 22, 2021 06:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
justin57
Aug 20, 2015 07:05 PM
