While I have the throttle body out....
Old Aug 15, 2005 | 12:08 PM
jcpegg's Avatar
What should I clean, inspect, replace, etc... I've only had this vehicle for a few months, so I have to assume that the throttle body has not ever been serviced. A little advice on how to remove/clean specific parts would help a lot since I'm new to fuel injection.
Old Aug 15, 2005 | 12:30 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
While you have it out I would do all of this: https://www.thirdgen.org/newdesign/t...matetbi2.shtml
It would save time later when you'll want to do those mods.
Old Aug 15, 2005 | 01:29 PM
STRIFE69's Avatar
Car: 91 camaro
Engine: 305TBI
Transmission: 5 speed
Check the vaccum lines for cracks,dry-rot,and such. Same with the eletrical wiring.
Check out The sticky... one that says New to TBI It should keep you busy or at least give you some pointers on what you can and can't do or might want to do.
https://www.thirdgen.org/techbb2/sho...hreadid=227281
Fuel injector spacer is something to consider. But you can order one and put it on later after you reinstalled the TB to your car. Just gotta be careful with the screws not to drop them. E-Bay is good spot to purchase one for decent price.
I learned most of my stuff just from reading the stickies. Well worth your time IMO.
Good luck!
Old Aug 15, 2005 | 02:51 PM
zeb1999's Avatar
Car: 97 Z, 92 C1500
Engine: 5.7L, 5.7L
Transmission: 6-spd, 4-spd auto
Check all the vacuum passages to make sure they are clear. It is very common for these to plug up (especially the PCV) on high mileage cars and it will give you all kinds of tuning fits.
Old Aug 16, 2005 | 08:57 AM
jcpegg's Avatar
Wow, this web site has a TON of good information! Until now I had only checked out this forum. Thanks for the links. I'll plan on just cleaning all of the parts and passages on the TBI and adjusting the TPS and IAC and checking the hoses and wires. I have a spare TBI that I might try to modify following oifish's advice. Thanks again for the advice!
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
