i`ve got weird heads!?!
Old Sep 8, 2005 | 03:12 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
my 88 had a new engine put in it about a year before i bought it.it was the 88-93 gm goodwrench engine.the part number on them is 10159551.has anybody ever heard of these.give me some insight if you can.thanx
Old Sep 8, 2005 | 03:19 PM
SchwarzCamaroRS's Avatar
later LO3 heads... http://www.usol.com/~okfoz/90/90technical.htm
Old Sep 8, 2005 | 03:24 PM
are they better than the regular heads?are they worth porting?or are they just a waste of time?
Old Sep 8, 2005 | 03:26 PM
proably the same as 193's not sure though... i couldnt find the casting number, only the part number... they are swirl ports so porting them will help, and if you already have them, no point in replacing them unless you plan on serious power... i could have ported my 350TBI heads instead of buying the 350TPI heads and getting them ported like i did and it would have made a marginal difference if i was done correctly...
Old Sep 8, 2005 | 03:28 PM
ok i`ll see if i can find alttle more info on them.
Old Sep 8, 2005 | 03:31 PM
10159551 - 305 - 87-94 - 1.84/1.50 - 58cc
theres the part number, engine, production years, int/exh valve sizes and the combustion chamber size...
maybe if a mod sees this they can put it somewhere... this is the most extensive list of GM cast heads ive ever seen... http://www.chevymania.com/partsid/pa...p=head&block=S
Old Sep 8, 2005 | 03:35 PM
you`re the man schwarz,good luck in cali dude.
Old Sep 8, 2005 | 03:37 PM
ty! your welcome man!
Old Sep 8, 2005 | 04:33 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That is a good reference. Thanks for the link! www.mortec.com is also tough to beat. They have everything.
Old Sep 8, 2005 | 05:05 PM
np, mortec is nuts as well. i like both
Old Sep 9, 2005 | 10:05 AM
the only question i have left is does anybody know if they are swirl ports or not?
Old Sep 10, 2005 | 03:58 AM
yes, yes they are...
Old Sep 10, 2005 | 04:00 PM
dammit!
Old Sep 11, 2005 | 07:01 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by robertfrank
dammit!
Eh don;t give up on them yet. Check out the links in the above stickes to swirl port head discussion. Use that info to judge for yourself. A little port work helps tremendously.
Old Sep 11, 2005 | 04:08 PM
thanx shifty i`ll give them a shot
Cleotiz
Jan 6, 2018 08:56 PM
87iroctheo
Dec 4, 2016 11:47 AM
NiG
Oct 11, 2015 08:42 PM
NiG
Sep 2, 2015 06:54 AM
CORV3TT3
Aug 23, 2015 11:26 AM
