In line fuel pressure adapter
Old Oct 12, 2005 | 12:16 PM
smikecq's Avatar
Car: 92 RS Convertable
Engine: 305 LO3
Transmission: 700 R4
Here are a couple pictures and a link for an in line fuel pressure tap. It is a clean install and very helpful when adjusting your fuel pressure.
http://www.actron.com/product_detail.php?pid=16175
The T-fitting is available seperate from the guage if needed
Old Oct 12, 2005 | 09:02 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I installed mine in the same place.
I also ran a length of hose from the end of the Schrader valve down to the bottom of the car in case the valve takes a dump while driving. I ran it through a hole in the frame to hold it in place.
I think in the fine print for that FP gauge, it says the valve/adapter fitting should be removed from the line when not in use.
Imagine the fire that would occur if the valve failed while driving!
Whoo-Haa!
S-D
Old Oct 12, 2005 | 09:20 PM
Car: 1991 RS
Something along these lines.
Old Mar 5, 2011 | 08:31 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Axle/Gears: 2.43 Gear Ratio
Re: In line fuel pressure adapter
I bought the same TBI fuel pressure guage and the darned thing will not screw into the t-fitting.
Old Mar 6, 2011 | 02:20 PM
ex-x-fire's Avatar
I've got that actron fuel tester for gm tbi, it only works w/ that adaptor. It wont screw onto the test port on other gms.
Hey Shady, did you buy it in a set? Whats not threading together?
Old Mar 6, 2011 | 05:07 PM
Engine: 350 S/B
The rubber end of the pressure guage will not screw into the rotating t section of the adapter. Maybe I'm just crazy.
Old Mar 6, 2011 | 06:36 PM
ex-x-fire's Avatar
I'd try to refund it. I bet its just a mix up. They sell that adaptor in a full Actron set which probably has the threading for normal GM test port.
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
