diy afpr what size screw?
Old Oct 16, 2005 | 08:27 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
i took my tbi apart to do the ultimate mods to it and i found that the screw for the fpr is to deep to really get any thing in there.what type of thread is the screw and if any are there alternatives for using it,like a longer one ?i would like to get one that sits aleast an inch past the opening next to the fuel lines. any thoughts.thanx in advance
Old Oct 16, 2005 | 09:13 PM
anybody?
Old Oct 16, 2005 | 09:54 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I did something similar to what I think your trying to do, correct me if I'm wrong. I just removed the stock screw all together but kept the cone-shaped piece installed, threaded the hole in the bottom of the FPR with a 3/8"-24 tap, and then threaded in a 3/8"-24 2" long bolt (cut down slightly). It works pretty well, too. Now all you have to do is remove the air cleaner to adjust the fuel pressure.
Here's some pics:
Can't take all of the credit for this though, I believe it was DM91RS that first did this. But, if you want or need more details, just ask.
Old Oct 16, 2005 | 10:22 PM
yeah thats exactly what i`m talking about.thanx
Old Oct 17, 2005 | 11:11 AM
Benm109's Avatar
Engine: 305 TBI
Couple of things I forgot to mention. You may or may not have to cut down that 2" long bolt or not, it just depends on how high your injector pod sits off of the TBI unit base. I'm running an injector spacer and at 2" it was just a hair too long. My goal was to cut it down to where it sat evenly between the top of the base and the MAP sensor vacuum port, so I can increase or decrease the pressure as needed.
Also, once you do this, it's not quite as easy to remove just the injector pod anymore, because that bolt has to come out first. Same thing happens when you go to install it. You have to put the bolt up through the TBI unit base, put the injector pod into position, then thread the bolt it and then you can install the injector pod. Overall, it's a little bit more work, but it's worth it. If you have the injector pod and fuel meter cover (with FPR on it) all as one piece when removing or installing it, it's just like before. If this doesn't make sense, you'll see what I'm talking about once you go to reinstall it.
Old Oct 17, 2005 | 08:34 PM
do you think a 3/8 16 bolt would work because i can`t find a tap for 3/8 24?
Old Oct 17, 2005 | 09:29 PM
Benm109's Avatar
Engine: 305 TBI
Yes, it will work just fine. The only reason I went with 3/8"-24 bolt was just because it's a finer thread. It makes it just a little easier to adjust it exactly where you want it, but a 3/8"-16 will work just as well.
Old Oct 17, 2005 | 09:56 PM
thanx man i really appreciate your help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
gta892000
Sep 16, 2015 12:37 AM
m00n420
Sep 11, 2015 02:39 PM
355tpipickup
Sep 4, 2015 05:32 PM
