Horse power? 1/4?
Old Nov 11, 2005 | 07:48 PM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Horse power? 1/4?
I would like to know of the potential of my l98 tbi motor that i am building. Here are the states of the engine. I would like to now what should i expect?
-l98 350 short block
-ported heads
-3 angle valve job
-(cam)duration266/ 276, Lift .500/ .510, lobe 114
-under drive pully, headers, borla,manifold,
-150n20
-some tunning
Thanks Eric
Old Nov 11, 2005 | 09:05 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Any one, want to know some info. thanks
Old Nov 11, 2005 | 09:40 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
what kind of heads will you be using? Don`t use the swirly`s cause everyone knows they suck *****.
Old Nov 11, 2005 | 10:17 PM
NEEDforSPEED's Avatar
did'nt know they could do that
Old Nov 11, 2005 | 10:23 PM
you nasty bastard
Old Nov 12, 2005 | 07:28 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
What? 083 heads
Old Nov 12, 2005 | 09:38 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
193 heads flow more on the exhaust side than a stock L98 head. On the intake side they only flow margonaly less. When ported they can support an easy 300 HP and 400+ lb ft of the good stuff. Refer to recent discussions and data provided by Fast355 and kdrolt.
They are not a performance head but recent data has shown thay they are not "worthless" as deemed by many. I too once thought these heads to be junk. New evidence has forced me to chance my stance on them.
Old Nov 12, 2005 | 04:39 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Thanks shifty, so what do you guys think are my stats?
Old Nov 12, 2005 | 07:18 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
A lot will depend on your ability to do the necessary chip work. Off the shelf chips will not suffice and you will have to learn yourself or have the car in the hands of someone who knows how to tune TBI set-ups. You will also need to add some feuling upgrades to your list. You will need a high capacity fuel pump as well as larger injectors. You can use the stock TBI unit to get you started but throughout the tuning process you will more than likely want to try a larger TBI unit.
I will assume that you already have a full exhaust from the headers back.
With those missing criteria filled in I would say you are looking at a solid 300 hp and a solid 13 second car.
Old Nov 13, 2005 | 01:26 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Stock 350 injectors will work? Which fuel pump do you recomend? -Eric
Old Nov 14, 2005 | 02:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
There are a few 350 injectors but any of them should work pending the adjustments you have with the regulator and chip work. Most here will recomend the walbro 190 fuel pump.
italiano67
Dec 11, 2016 09:21 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
scottmoyer
Sep 5, 2015 09:33 AM
Chevy3shitty
Sep 1, 2015 02:10 AM
sailtexas186548
Aug 24, 2015 10:11 PM
