Please Help, Which push rods with the LT1 Cam swap??
Old Jan 22, 2006 | 08:08 PM
drews91maro's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I've searched over and over and cannot find threads with the info i need. I am putting a LT1 cam in my 305 TBI with the comp cam springs like the thread said to do. My car has 147k miles on it so while i'm tearing into it all i wanna replace other parts such as the lifters and push rods, whether they "need" it or not. I figure I might as well do it while I have it all apart. I'm kinda new at the whole valve train stuff, so can anybody tell me what push rods to use as a replacement. I'm not neccessarily looking for an upgrade, considering the stock ones will work. I'm more or less looking to replace the olds ones with new ones. But if there are some better ones i'm open to suggestions. What I really need to know is the specs on the factory push rods in my car so i can look for new ones....Please any help will be great! Thanks!
Old Jan 22, 2006 | 08:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Stock replacements are fine as well as any stock sized (5/16" diameter, 7.195" long)
aftermarket ones.
GM Part #10046173
Here are some that will work. They range in price based on heat treament and material. Cheap ones are fine for your application.
Here are some Summit Racing part numbers.
CRN-10621-16
SUM-1457200
TFS-21407200
SUM-G6406
CCA-7972-16
CCA-7808-16
Old Jan 23, 2006 | 07:54 AM
Car: 91 RS Camaro
Engine: 305 TBI
Thanks alot for the info! I need that!
Old Jan 26, 2006 | 08:32 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
LT1/Z28 springs would be good enoughj, right ? I'm asking since I've seen an ad in a car magazine, something like 27 or 28 bucks for the set.
Old Jan 26, 2006 | 09:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If you search here on TGO for "Z28 springs" you will get a series of horror stories. From what I read, and I have no reason to doubt, they are junk and will not be adequate. You are better off paying $50 for a comp 981 spring (good for LTX cams) or equivalent.
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
st.evel07
Aug 13, 2015 06:15 PM
