TBI worth using?
Old Mar 5, 2006 | 06:55 PM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
TBI worth using?
im building my 350 right now and i have a TBI intake manifold laying around and 1 1/2 throttle bodies (the 1/2 one has 350 injectors the whole one is off a 4.3) with the right modifications to the throttle body will TBI work well on a moderately high performance engine?
Old Mar 5, 2006 | 11:38 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
What is moderate to you?
Old Mar 6, 2006 | 09:55 AM
muteboy49's Avatar
Car: 84 Camaro
my motor will have somewhere around 350 HP and 370 ft lb
Old Mar 8, 2006 | 06:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
TBI can support 350hp but it will require large injectors, 2" unit (holley or 454 GM TBI) and alot of tuning. The stock sized TBI unit can support a decent amount of power but will not fid your power goals.
Old Mar 10, 2006 | 05:27 PM
1992camarors's Avatar
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
The stock 305 TBI can support a 400ci engine. The 350 TBI a little more. But a performacne TBI can handle up to 900hp. TBI is defiantly worth using. But if I were you I would get the 454 TBI because of your engine set-up.
Old Mar 11, 2006 | 07:53 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Umm, I don't know where you got your information, but listen to shifty he knows what he's talking about. There isn't a factory style, 2-barrel TBI that will support 900 hp.
Old Mar 11, 2006 | 08:30 AM
Engine: 305 TBI
I wasn't saying that their was a factory TBI that could handle 900hp. But thier is one made by turbocity.com(4b TBI). I do know my stuff about TBI, and I would of not have posted it if it wasn't true.
Old Mar 11, 2006 | 11:33 AM
BMmonteSS's Avatar
Car: 84' Monte
With 23 post to your name, I doubt you know as much as shifty or some of the others on the boards. The 4-barrel TBI is made by holley and requires a holley specific ecm to use. Some have tried it with our factory ecm, and even with lots of tuning results are marginal. With the cost of the 4-barrel and the ecm you can go multi port, so it pretty much corners a non-existant part of the market. Didn't mean to step on your toes, but your info is a little off.
Also saying a 305 TBI will "feed" a 400 is misleading, sure it will feed a stock 400, but what happens when he gets up in the 300-400 HP range and wants to turn 7000 RPM? No way it will work then, a BB unit would have a hard time with that.
The facts are, a stock TBI with big enough injectors will support around 300 HP without too much restriction. A BB TBI with 2" bores and 80 lb/hr injectors with fuel pressure in the high 20's will support around 400 HP. TBI is fuel limitied, not air limited.
This has been covered a bajillion times before
wigmobile
Feb 26, 2025 02:56 PM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
amcnellis
Sep 16, 2015 04:16 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
